Glass Scratch Removal
Old Apr 17, 2006 | 12:42 PM
captainmorgan's Avatar
captainmorgan
Default Glass Scratch Removal
Has anyone removed scratches from the side windows?
What did you use?
Old Apr 17, 2006 | 01:36 PM
LittleJake's Avatar
LittleJake
Im also interested in this.
ttt
Old Apr 17, 2006 | 01:47 PM
jclit's Avatar
jclit
me 2
Old Apr 17, 2006 | 01:50 PM
Jerry Curl's Avatar
Jerry Curl
Me three.
Old Apr 17, 2006 | 01:51 PM
81cali's Avatar
81cali
Some years ago, there was a company that came up with this product that you apply to remove scratches on glass. It was even advertised on tv showing the removal of worn out wiper scratches on windshields. Can anyone remember this?
Old Apr 17, 2006 | 01:56 PM
pws69's Avatar
pws69
Sssssssnake oil.....
Old Apr 17, 2006 | 02:04 PM
SIXFOOTER's Avatar
SIXFOOTER
Yea I remember seeing it, I think JC Whitney still sells it. I have also seen the work. Yes it will remove SOME scratches, but it also introduces swirls, will make you dizzy lookin thru them.
Old Apr 17, 2006 | 02:14 PM
wcsinx's Avatar
wcsinx
Yeah, I've seen some of the handiwork of these DIY glass buffing kits. They only come with 1 grit and it's too big for finish work. Any glass shop should be setup to do this stuff though. I'd check your yellowpages. It's not an expensive thing to have done.
Niart01's Avatar
Niart01
Default Glass Scratch removal
Whenever I paint a car and do the buffing, I make sure to put polishing compound on the windows and buffing removes a lot of small scratches. If it is a bigger scratch you can take it to a glass shop and the have a fill in process they use for nicks on the windshield. It also works for side windows.
Old Apr 17, 2006 | 02:26 PM
toolking's Avatar
toolking
They have it because they will attempt to remove scratches from the ones they sell that come with minor scratches.
It will, however, only remove minor scratches.
Old Apr 17, 2006 | 02:31 PM
onaqwst's Avatar
onaqwst
there is an acrylic buffing compound that has 3 stages of grits and a polish....... that might work and not tooo harsh... even though acrylic is softer than glass, i'm sure it'll help out a bit...... i'll see if i can find the name
b
Old Apr 17, 2006 | 02:51 PM
rihwoods's Avatar
rihwoods
Nothing I've tried has worked on the "deeper" scratches..even those "glass" guys can't fix it...but I use Rain*X Glass Care 2000...it does a good job on the teeny weeny scratches....it is a glass cleaning/polishing compound..you can feel the grit between your fingers..
Old Apr 17, 2006 | 04:21 PM
Edzred72's Avatar
Edzred72
I have used Eastwoods "Glass Polishing Compound" with great success, but it only removes haze, discoloration, and tiny surface scratches.
Eastwood does sell a glass grinding kit that removes deeper scratches, but warns that distortion may occur is not done correctly. Also checked into having the glass ground at a shop. They wanted $75 an hour with a minumum 1.5 hrs per side. NO THANKS!!!!
Eddie
Old Apr 17, 2006 | 04:35 PM
rihwoods's Avatar
rihwoods
Yeah..I can't afford to have my glass distorted..
Old Apr 17, 2006 | 04:42 PM
my red 81's Avatar
my red 81
i had the marks that steel makes when the rubber on the windsheld wipers are gone you could not miss it when you looked at the windsheld.
i got that kit ecklers sells and when to town on it took four hours work and made a big mess but they came out ,you cant see them now and its clear you have to go slow and use lots of water.
let me ad side windows are temperd it can break maybe ?
Old Apr 17, 2006 | 05:53 PM
Sprzout's Avatar
Sprzout
Eddie
Good to know about the Eastwood stuff; my dad was going to try it on his Jaguar's windshield since there's some pretty heavy scratches and pitting. If it leaves swirls, he's not going to be happy with that...
Old Apr 17, 2006 | 08:27 PM
lowbuck72's Avatar
lowbuck72
I bought the JC Whitney kit , for my '55 Chevy. It took a lot of patience, but it got out some pretty deep windshield wiper scratches. Cost $29.95, saved my windshield...
To Glass Scratch Removal
Old Apr 18, 2006 | 12:09 AM
Strats-N-Vettes's Avatar
Strats-N-Vettes
Friend Request Magnet
Default Old School
Actually; "back in the day"...we used regular ole chrome polish(ie. the Turtle wax brand that was brown) for glass...that was the ticket back then (and mostly by-hand polishing)...
With todays small and compact cordless drills; its EZ...it wont remove gouges, but all scratches will go, calcium, lime, and other hard water deposits/stains will go....be careful next to old rubber trim, gaskets and seals.
Old glass is different from today's glass...chrome polish really doesnt work on newer glass as well.
There was also a product called "Allisons 20/20 Bubble Polish" it was made for helicopters since most of those didnt have windshield wipers.
You will also notice "Rain-X" (and the like) work better on old glass than new...again; its the materials in glass these days.
Chrome polish may take a few tries at first, but after that; its as easy as keeping a good wax job on the car.
Low $$$, elbow grease, effective results.
Jim
Old Apr 18, 2006 | 02:54 AM
Muddywaters's Avatar
Muddywaters
Eddie
Eddie: couple of days ago, I also purchased Eastwoods... Haze & light scratch solution, (still in transit) any suggestions on its use? Thanks heaps! Muddy
Old Apr 18, 2006 | 04:48 AM
Bangkok Dean's Avatar
Bangkok Dean
I have heard lots of folks getting there windshields repaired but the side windows are tempered glass. I have not heard of anyone removing scratches from them.
