Repair/replace
Old Apr 17, 2006 | 04:26 PM
JustForFun's Avatar
JustForFun
Default Repair/replace
radiator sprung a small leak. im sure more might be coming in the future and i want from here forward to be trouble free. would i be better off having the rad i have now recored, or should i just spend the 175.00 and replace the whole unit.
signed:
Leaking radiator after everything was reinstalled
Old Apr 17, 2006 | 04:36 PM
JoeRags's Avatar
JoeRags
DeWitts!!!!!!
expensive, but some of the best radiators on the market for our cars. I'm sure many others will tell you the same.
Old Apr 17, 2006 | 05:05 PM
NHvette's Avatar
NHvette
I would tell you to have it recored.
Most radiators for $175 are aluminum/plastic ... and don't hold up long term.
That is, unless you have an extra 5 bills to spend on a radiator. I don't.
Then, by all means get a direct fit aluminum. Some day I will.
Old Apr 17, 2006 | 05:15 PM
JustForFun's Avatar
JustForFun
$175.00 one has lifetime warranty. I work in automotive field and are saving about 50%. Car will be driven about 2-3 times a month. radiator in there has lasted 25 years and has worked fine. Wasnt sure if recoring was much cheaper or not
Old Apr 17, 2006 | 05:20 PM
JoeRags's Avatar
JoeRags
is it the core thats leaking? or one of the end tanks? If its just the core, I dont see why you shouldnt... not sure on pricing, but guess its something to look into.
To Repair/replace
