Grounds
- negative battery cable to frame under battery box
- under passenger side motor mount bracket, frame to engine
- under front of drivers side rocker molding, frame to birdcage (rocker channel)
- front drivers side of radiator support, wiring harness to support
- headlight header bar, near horn mounting
- passenger side tranny bellhousing, wiring harness to bellhousing
- under drivers kickpanel (maybe passenger, too), wiring harness to birdcage
- several on the taillight housing mounting studs (under tail end)
- license plate light housing
- gas tank sender unit
- antenna ground plate
That's all I can think of off the top of my head.
