what a surprise...
Apr 24, 2006 | 08:58 PM
Cruise-In VII Veteran
St. Donor '03 & '06
what a surprise...
it's leaking again.
Apr 24, 2006 | 08:59 PM
Cruise-In IV Veteran
Apr 24, 2006 | 09:01 PM
St. Donor '03 & '06
nope... guess again.
it's on the driveway.
Apr 24, 2006 | 09:03 PM
hmmm...
black
red
or green
St. Donor '03 & '06
don't know yet... it's a gravel driveway.
I put some card board under it, so I'll find out in the morning.
Apr 25, 2006 | 10:48 AM
St. Donor '03 & '06
Apr 25, 2006 | 12:11 PM
wheres it coming from ?
back of engine, front, side??
Apr 25, 2006 | 12:29 PM
St. Donor '03 & '06
I dunno yet.
appears to be from the rear area.
probably check later when it's not raining.
Apr 25, 2006 | 12:35 PM
Canadian Events Coordinator
Apr 25, 2006 | 12:38 PM
my moneys on the rear main seal..
send it to a detailer, get it shined up as best as it can be, and unload it
Apr 25, 2006 | 12:44 PM
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Quote:
Originally Posted by MonteHall
yep... it's oil.
Chack the valve cover gasket rears...drip down Leak...maybe the transmission seal too wahing old dirt & oil down through the inspection cover.good luck
Apr 25, 2006 | 03:51 PM
St. Donor '03 & '06
Quote:
all transmission seals are less then 2 months old.
Apr 25, 2006 | 04:00 PM
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Mine has a small leak at the oil sending unit. Easy to tell because it's up high on the rear of the block.
Apr 25, 2006 | 04:19 PM
It's a C3, it's marking it's spot and its also an early level warning system, when the leaking stops it's empty
Apr 25, 2006 | 04:42 PM
Quote:
just keep your eye on the levels.
big spot? or just a drop here and there?
Apr 25, 2006 | 06:52 PM
St. Donor '03 & '06
pretty sure it's the oil sender.
