hood removel
A 2-person job.
No way you can hold up the far side after it's been unbolted while you unbolt the other side.
Can it be done with one person. any suggestions would be helpful.
thanks
Remove one bolt only from each side, leaving the other bolt completely tight.
Replace these bolts with a threaded piece of metal rod (with the same thread, obviously). The metal rod should be about 3 inches long, and the excess will stick out through the hood hinge.
Now remove the other two bolts. The metal rod will hold the hood in place while you remove the hood support bolts. Be sure the support the hood, since you can't close it because of the metal rods.
Now, lower the hood until is is open about a foot at the rear, then reach across the hood and grab the opposite edge. Lift the hood striaght up while slowly wiggling the hood to get it free of the hood hinges.
Like I said, difficult, but it can be done. Much easier, and safer, to use two people.
i have exposed rafters in my garage. i raise the hood and tie the grill at the back of the hood to the rafters above. then you can remove the bolts at the hinge and raise the hood up out of the way. i then put one bolt back into the hood on each side to give me something to tie it up to.
it comes down just as easy.
