My Bra Falls Off!
Old Apr 28, 2006 | 11:01 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Default My Bra Falls Off!
And it's not pretty either. Just bought this BRA (nose protector) and can't seem to get past the 2nd step of the instructions below. The hood surround has a lip that faces down, but the reinforcement steel is so close that there is no room for these "U" shaped trim lock clips that are described. Are the clips intended to grab only one side of the vinyl or does the vinyl make a loop inside the clip like using clothes pins on a laundry line? The flap described runs the entire length of the hood surround. Are only 2 clips supposed to be enough, that is if you could even get them attached?
It also looks like the instructions contradict themselves. (2) hooked-back U-shaped trim locks are used in steps 3,4,and 5, then 2 more are used in step 6. The kit only comes with 2 according to the material list.
Old Apr 28, 2006 | 11:29 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Bra's are for one thing, and unless you have two (Vette's), thats not it... my .02
Old Apr 28, 2006 | 11:34 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
you must have some big ones
Old Apr 28, 2006 | 11:38 PM
Big Fish's Avatar
Big Fish
Originally Posted by Glass Act
Bra's are for one thing, and unless you have two Vette's, thats not it... my .02
I've never been real impressed by them either, but have a long trip coming up (CI-7) Tired of all the chips I get. Surely someone has been successful in getting one of these things to fit on a C3.
Old Apr 28, 2006 | 11:41 PM
Big Fish's Avatar
Big Fish
They keep getting bigger (to stay in proportion with my mid-section?) I didn't have hardly anything when I was younger.
Old Apr 29, 2006 | 06:40 AM
fl_rider's Avatar
fl_rider
Default My .02
As shi-crappy as my paint is I still "WOULDN'T" put a bra on my car.
It's only going to do more damage rubbing the paint off.
Chris B
Old Apr 29, 2006 | 07:50 AM
gator79's Avatar
gator79
Chris B
women and cars should all be braless
Old Apr 29, 2006 | 11:06 AM
Glassbowtie77's Avatar
Glassbowtie77
You either need bigger headlights or a smaller bra!
Old Apr 29, 2006 | 12:47 PM
Fevre's Avatar
Fevre
My nose cone is old and cracked, actually has a hole in it so I bought a bra. Thing fit like **** so I modified it a bit , see sig
Old Apr 29, 2006 | 01:15 PM
Big Fish's Avatar
Big Fish
I've seen those partials (demi-cups?) Maybe I should have gone that way. I have had rock chips on the headlight doors and high up on the front fenders though.
Old Apr 29, 2006 | 10:28 PM
glen242's Avatar
glen242
What brand? I put a "Le Bra" brand on my daughter's 3000 GT and it was an excellent fit. Cost a little more but .....
Old Apr 29, 2006 | 11:44 PM
Big Fish's Avatar
Big Fish
Doesn't seem to be a brand at all. It is a GM licensed product purchased from Corvette Central. I think it's going to go back on Monday.
Old Apr 30, 2006 | 12:41 AM
logansrun73's Avatar
logansrun73
St. Jude Donor '14
I had no problem with my bra. It is a wolf. Got it because my front bumper is falling apart. Just a cheap fix for a while.
Old Apr 30, 2006 | 12:57 AM
Big Fish's Avatar
Big Fish
Mine looks identical to yours except I have a crossed flags logo. Even the same airfoils, but I'm not sure what they actually do if anything. How does yours attach to the hood surround, along the front edge of the hood?
Old Apr 30, 2006 | 01:01 AM
logansrun73
St. Jude Donor '14
It does not attach to the front of the hood. It attaches to my wheel wells and under the front bumper.
Old Apr 30, 2006 | 01:05 AM
Big Fish's Avatar
Big Fish
Interesting. Apparently mine is a different brand. Yours does look good and appears to fit pretty well. Does it flap when you are traveling at all?
Old Apr 30, 2006 | 12:26 PM
AA2PR's Avatar
AA2PR
Default painfull event
Hope you didn,t run over your ****, that could hurt real bad.
To My Bra Falls Off!
Old May 3, 2006 | 09:29 PM
Gary's 1977 Vette's Avatar
Gary's 1977 Vette
Well that is the problem you are reading the instructions!! LOL I got a bra for my '77 just to use on long trips to protect the paint and like the other guy said it don't fit very gooe at all. The biggest problem is the pop up lights and the way you have to attach it to them. I kind of like the modified one like Chris LeFevre did where it just covers the nose because that is where you will get the most chips.
Old May 4, 2006 | 12:32 AM
Big Fish's Avatar
Big Fish
As frustrating as this thing is, I'm beginning to think there might be hope. I have decided to add a continuous velcro soft strip to the hood surround flap, and that will attach to a continuous velcro hook strip glued underneath the hood surround. That should hold the trailing edge of the bra very secure and allow me to get a nice tight fit everywhere else. I swear this manufacturer has never tried to install this product on a C3. As I mentioned already, this came from Corvette Central and they have always sold very excellent products to me in the past. I am planning on letting them know about the problems I have had with this one, think they need to change vendors or demand something better.
Old May 4, 2006 | 01:10 AM
JoeRags's Avatar
JoeRags
