Power windows... They quit !
Old May 1, 2006 | 06:27 PM
jrs 427's Avatar
jrs 427
Default Power windows... They quit !
The power windows in my 75 convert just up and quit. They are in the down position ( which is good ) but am I missing a relay or something here ? If one went I would just assume the motor was bad but I can't see a reason for them to both die at the same time. Anyone had this problem ? The car has been sitting for many years.
Old May 1, 2006 | 06:31 PM
jdp6000's Avatar
jdp6000
Thats odd. They aren't in series. One should work even if the other doesn't. You check the fuse???
Jim
Old May 1, 2006 | 07:34 PM
jrs 427's Avatar
jrs 427
Fuse checks out. Switches don't seem to have power. That is why I am wondering if there is a relay or control between them. The car sat a long time.... might be corosion also.
Old May 1, 2006 | 07:35 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
on my 77 there is a plug that plugs into the front of the panel... make sure that all of them are in properly...
Old May 1, 2006 | 07:41 PM
BarryK's Avatar
BarryK
I would imagine that the power window wiring is the same in '75 as it is in '78.
Assuming that it is, and since both windows quit together, I'd check the pink wire that goes to each PW switch on the console plate. This is the only wire that is common to both windows and would explain why both would quit at the same time.
The pink wire goes to the center connector on each switch and is the hot lead power wire for the switches and they join together and go to the PW relay. That relay is fed by the fuse panel "ign" tap and than goes to the ignition switch.
I'd first check to see if you are getting proper power and ground at the PW relay. if you are, than either the relay is bad or there is a break in the pink wire between the relay and the switches.
If you aren't getting good power and ground at the relay than it somewhere between the switch and fuse panel or fuse panel and relay.
If you need, email me or PM me with your email address and I'll send you a pic of the wiring schematic of that circuit from my '78 schematic
Old May 1, 2006 | 07:57 PM
REDRED62's Avatar
REDRED62
The power window harness plugs in to the fuse box on your car. I personally have slid in to the seat and kick the plug loose with my monster foot!
You might check this first since it's an easy fix. Main power feed has a connector that is pushed in to the front of the panel.
If you are plugged in, then check to see if you have voltage on the red wire on the switch.
jrs 427's Avatar
jrs 427
E mail on the way.... Thanks !!
Old May 1, 2006 | 08:04 PM
SEASND VETTE's Avatar
SEASND VETTE
If all else fails take the panel off and hit the motor gently with a hammer,mine did the same thing last summer after that it's ran smooth ever since ?
Old May 1, 2006 | 09:03 PM
REDRED62's Avatar
REDRED62
You can find a schematic on a 1978 at this link. It's an actual enlarged copy. This is the same for your car.
http://www.corvetteforum.net/c3/tune.../index22.shtml
Old May 2, 2006 | 01:50 AM
Love My 72 and 77's Avatar
Love My 72 and 77
I big pink wire fell out of the middle of my fuse panel and shut down both my windows in my 77.
Old May 2, 2006 | 07:20 AM
Aflac's Avatar
Aflac
St. Jude Donor '09
that happened to me at night when it was starting to rain. there's nothin like crawling under your dash in the dark trying to put that dang thing on!
To Power windows... They quit !
