OK humor me.....
Old May 2, 2006 | 12:20 AM
'Bochawa72's Avatar
'Bochawa72
Default OK humor me.....
So I haven't had my Vette a week yet and I was showing it off to some friends tonight. One of them says "So if it doesn't have a trunk then what's that keyhole for?" He points at the keyhole above the corvette lettering on the tail of the car. And honestly I have no idea...none of my keys will fit. Crawling under the back and looking up doesn't give any hints either. No mention in the owners manual. So I'm stumped... What's that keyhole for?
-CR
Old May 2, 2006 | 12:26 AM
Corz's Avatar
Corz
Cruise-In IV Veteran
that unlocks the 'hump me' hole
im pretty sure its for the alarm that never works right
Old May 2, 2006 | 12:44 AM
ngbrinkl's Avatar
ngbrinkl
two correct...its the alarm alright, and it never ever works right
Old May 2, 2006 | 01:17 AM
rathvon350's Avatar
rathvon350
I had the same problem only mine was on the drivers side fender. Everyone thought it was to lock the hood. I guess thats a common thing to lock...WHAT!
Old May 2, 2006 | 01:28 AM
TonySinclair's Avatar
TonySinclair
Don't listen to these noobs...the keyhole is for the optional rear hatch:
Old May 2, 2006 | 01:44 AM
BLUSHRK's Avatar
BLUSHRK
what the hell?!
Old May 2, 2006 | 07:17 AM
kidneyboy's Avatar
kidneyboy
Old May 2, 2006 | 07:44 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
There ya go.
Old May 2, 2006 | 07:56 AM
smthnpls's Avatar
smthnpls
too funny!
Old May 2, 2006 | 09:43 AM
JPhil's Avatar
JPhil
It activates the cloak of invisibility. Never worked right from the factory, and C3 owners wouldn't use it anyway.
Old May 2, 2006 | 10:10 AM
Scottys78's Avatar
Scottys78
Old May 2, 2006 | 11:47 AM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
Your next assignment is to find the RPO # for the station wagon option in the Corvette Black Book.
Old May 4, 2006 | 02:06 AM
BLUSHRK's Avatar
BLUSHRK
is it me or is that door panel fuzzy?!
Old May 4, 2006 | 10:45 AM
Flagstaff_Vette's Avatar
Flagstaff_Vette
Harold and Mause - Corvette Edition - love it. Actually GM thought about a 2 door wagon back in the 50's.....
Cool car. Room for the dog!
Old May 4, 2006 | 11:24 AM
kdf1986's Avatar
kdf1986
Here are some other helpful hints for a new corvette owner.
The battery is in the compartment behind the drivers seat.
The tire jack should be under the compartment behind the passenger seat.
The manual headlight actuator is one of the ***** under the dash, below the steering wheel. The other **** should be your tripometer reset.
And no, the clocks dont work. ( at least most of them dont.)
kdf
Old May 4, 2006 | 11:31 AM
JoeRags's Avatar
JoeRags
Old May 4, 2006 | 11:36 AM
kalister1's Avatar
kalister1
I thought the other **** was for the windshield wiper door?
To OK humor me.....
Old May 4, 2006 | 11:39 AM
kdf1986's Avatar
kdf1986
That may depend on the year. I didnt check to see what year he had.
My 72 has a big **** for the wiper door. My 73 and 75 do not have the wiper door, so the **** is not there.
kdf
Old May 4, 2006 | 11:56 AM
Niart01's Avatar
Niart01
Default Key hole
On My 73 the alarm does not work, and who would give a Rodents Rectum it it did and was beeping. I use the switch as a kill switch to ground the ignition. Seems like a much better use to me. Most crooks would not think about that. (now that I let the cat out of the bag, I will need to do something else).
Old May 4, 2006 | 12:24 PM
kalister1's Avatar
kalister1
I used a kill switch that was spliced in AFTER a fuse holder. If someone tried to start the car the fuse would blow, then even if they found your switch the fuse would need to be replaced too.
