Bulb kit from Ecklers
I just got the bulb kit from ecklers for my 69 and I was wondering if there is some link to a bulb diagram? I know where most of them go but some are in question, I do not have a light bezel for the cargo area, I am not even sure if there is supposed to be one there or not on a 69, it looks like there is a metal retainer directly above the middle cargo box, where a light bezel would be attatched but I see no wires.
I also see a spot where a bulb is supposed to go in the middle compartment box but it has the switch and 2 wires coming off and nothing connected to the wires, so I am not sure what I need to do there? Just run a power wire to it? why would there be 2 wires? any help there would be appreciated!
I also am not sure about the passanger side courtasy light and where it goes. is there just a socket for it or is there a bezel it is supposed to be in? thanks.
I put in a new heater control face plate and noticed there is a bulb there, not including the one in the cigaret lighter not sure what or where it is supposed to go, saw no retainer for the bulb just loose.
Thanks for any help or links to bulb wiring and harness diagrams!!!
do you have the AIM?
the one i have for my 73 shows very clearly where the bulbs are located...
if you don't have an AIM and a factory service manual, get one. they are both jam packed with usefull information. just about everything you could want to know is in there. most all of the usuall vendors will have these.
good luck
Mike.
good luck
Mike.
