front brake line question
Old May 4, 2006 | 07:18 PM
evil herbavore's Avatar
evil herbavore
Default front brake line question
Didn't find an answer in the search....
I wanted to see if anyone here has replaced the hard line for the left front caliper, from the distribution block to the flex line.
It appears to run under the upper control arms and I was wondering if it can be persuaded in without taking the front end apart.
Old May 4, 2006 | 11:00 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
what year is your car? what side pass or drivers side? I have pics of both in my photos. If your car is a 77 you should be able to change both without removing any front suspension parts.
Neal
Old May 4, 2006 | 11:27 PM
johnt365's Avatar
johnt365
i replaced both hard lines for the front on my 74 and only took the wheels off.
i may have bent it up a little comming out...
Old May 5, 2006 | 08:18 AM
Edzred72's Avatar
Edzred72
Yes, it can be done and is not hard. Might have to bend it up "a little" to sneak it under the upper c-arm like johnt365 said. Give it a try!!!
Eddie
Old May 5, 2006 | 09:17 AM
pws69's Avatar
pws69
I replaced ALL the lines in my 69 with Stainless Steel lines with the body on and without taking anything apart.
Old May 5, 2006 | 09:33 AM
Stewart's74's Avatar
Stewart's74
I replaced both brake and fuel...
Old May 5, 2006 | 11:25 AM
eddiemeddiem's Avatar
eddiemeddiem
I just replaced that line last weekend - it's possible!!!
Just take your time as your work the new line into place - it'll bend a little, but you can just bend it back.
Old May 5, 2006 | 11:35 AM
NHvette's Avatar
NHvette
... and put some tape over the ends as you get it into place ....
unless your chassis and engine compartment are spotless.
Masking tape is fine ... just keep the greasy dirt from getting jammed
inside and on the nut threads. If it is not stainless, give the line a
shot of clearcoat before installing.
Good Luck
Old May 5, 2006 | 01:30 PM
pws69's Avatar
pws69
I'm impressed! Tell me about the fuel line replacement with the body on. I have some S/S Braided waiting to go in place of my leaky steel line!
Old May 5, 2006 | 03:11 PM
70 LS1's Avatar
70 LS1
Me too.
Old May 5, 2006 | 04:02 PM
Stewart's74
I think the key to success is to get the car up on jackstands as high as possible. Fish the line from inside the rear wheel well. Braded lines should be a snap. I used SS and it took patience....something which I have little..
To front brake line question
