need fast help removing dash
Old May 5, 2006 | 11:10 PM
Enersis's Avatar
Enersis
Default need fast help removing dash
I cant find any skrews or bolts to get the top of the dash loose and off
Old May 5, 2006 | 11:33 PM
Buzzardz_vette's Avatar
Buzzardz_vette
On my 75 and 76, the top dash is held in place by one screw on the underside bracket (once you remove the front dashes that srew into the top dash). The windshield pillar trim pieces hold the ends of the dash down, so you will need to remove at least one of them. You will also have the bend the dash slightly up in the center to get it out.
Old May 5, 2006 | 11:39 PM
Enersis's Avatar
Enersis
thank you
To need fast help removing dash
