DeWitt radiator
Old May 6, 2006 | 08:14 AM
Phil Zell's Avatar
Phil Zell
Default DeWitt radiator
Installin new DeWitt twin spal radiator in my 75 this weekend.
new 383, What cap do I need.
Thanks All.
Old May 6, 2006 | 10:54 AM
MsVetteMan's Avatar
MsVetteMan
Patience.........
Does yours have the plastic fan shroud? What a pita. I'll save you some grief, when you finally work it out of there (take the fan off, belts, pulley) cut the thing in half vertically. I made a bracket that goes on top to hold it firmily back in place once easily reinstalled.
You will probably have to play around with the top rad. brackets, as they want to hit on the welds, instead of inside of them.
Good luck, and make sure you unhook those tranny lines!!
Old May 6, 2006 | 11:12 AM
chevylit's Avatar
chevylit
Put a DeWitt "direct fit" in My 79 a couple of months ago and used
original cap with no problems. I agree with MsVetteMan, the top rad.
brackets are a little hard to get over the welds on the tank, but I
still think buying the rad. was some of the best money I have spent
on My 79"money pit".
Old May 7, 2006 | 12:35 AM
Buzzardz_vette's Avatar
Buzzardz_vette
Originally Posted by MsVetteMan
Patience.........
If you put in Dual SPAL fans, you don't need a shroud. We just install the fans in my son's 75 and they look great. There's a lot off room in there w/o the shroud.
Old May 9, 2006 | 09:47 PM
Phil Zell's Avatar
Phil Zell
What is the pressure for the radiator cap?,
Old May 9, 2006 | 10:29 PM
chevylit's Avatar
chevylit
As stated in earlier post,used original RC 33 cap which is 15 lb.
Works great ,car is running around 170 degrees no matter how I drive it.
Old May 9, 2006 | 10:33 PM
chevylit's Avatar
chevylit
TTT
To DeWitt radiator
