Radiator question
Old May 8, 2006 | 05:57 PM
Joes80's Avatar
Joes80
Default Radiator question
I have to buy a new radiator and I was wondering if anyone has ever ordered one from Pep Boys? Ecklers, CA, both have a brass one it's around $250. Pep Boys says they have two brands Spectra, $149 and Line(?) $200. Any input is appreciated.
Joe
Old May 8, 2006 | 06:00 PM
Flagstaff_Vette's Avatar
Flagstaff_Vette
Dunno - I went with an alum radiator. C3's weren't noted for thier cooling capabilities. Rather have a cool engine than an overheated former engine... Buy the best your wallet can handle.
Old May 8, 2006 | 06:06 PM
Beater's Avatar
Beater
Spend the money on the Dewitts.
Old May 8, 2006 | 06:11 PM
cchristo's Avatar
cchristo
I got mine from Autozone. Probably very similar to what you are looking at.
I run dual electric fans, FYI.
The radiator looked good, and bolted right in without any drama. I had not seen north of 185 degrees until I installed the TH700r4 tranny and a bit higher stall torque converter. With the new converter and tranny, it keeps it under well under 200.
I think I bought the radiator a couple years ago, and I've had no problems with it at all.
I bought the more expensive of the two offered, I think it listed as the "heavy duty" radiator.
Bottom line.......No regrets here.
Old May 8, 2006 | 06:30 PM
Joes80's Avatar
Joes80
Might as well get all the hoses, thermostat and housing while I am at it.
Should I get 160 or 180? Or is the 180 stock? same price I just want to get the right one.
Old May 8, 2006 | 06:53 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
180 Larry
Old May 8, 2006 | 06:57 PM
Joes80's Avatar
Joes80
Thanks.....
Old May 8, 2006 | 07:03 PM
c3dreamer's Avatar
c3dreamer
Old May 8, 2006 | 07:26 PM
PEPTO77's Avatar
PEPTO77
Put an aluminum rad from DeWitts in my '72 earlier this spring. What a difference in water and cabin temps. Go for the Dewitts direct replacement aluminum rad!!!!!
To Radiator question
