Radio Bezel
Old May 9, 2006 | 09:38 AM
mandm1200's Avatar
mandm1200
Default Radio Bezel
I read a lot of threads on stereo upgrades; however, I have yet to see where to get/buy a bezel to dress up the installation. The head unit I going to be using is the type with a removeable faceplate. The factory center cluster bezel has already been enlarged years ago when I installed an Alpine unit in it. I plan on opening it up more to accomadate the new unit. I can make my own bezel but I feel it will take a couple of hours to: make a template, cut it, bend it, grind it, paint it, ect.
Old May 9, 2006 | 09:57 AM
Flagstaff_Vette's Avatar
Flagstaff_Vette
I bought mine from Corvette Central. SAVE YOUR OLD ONE. Anyway - I got a full metal one outta them, but it wasn't cheap. Looks good tho. Happy Tunes.
Old May 9, 2006 | 10:04 AM
monza_man's Avatar
monza_man
Same here!
Old May 9, 2006 | 10:15 AM
TonySinclair's Avatar
TonySinclair
I'm trying to decide what's cheaper...purchase the modified bezel that has the DIN cut-out or a radio that will fit my existing bezel. I already have a DIN radio (Pioneer SuperTuner) that's never been installed.
Cutting the bezel is not an option. Too much work for marginal results.
Suggestions?
Old May 9, 2006 | 10:20 AM
Flagstaff_Vette
Tony - buy a DIN from them - they did a good laser cut job on the metal. Unless you have a laser cutter available.
I have an Alpine Flip up Face DVD/Navi unit going in. Havent found where I'm gonna put the Fosgates. Considering run flats, and modifing the spare tire carrier with a new carrier, saving the old parts. Anyone done this?
Old May 9, 2006 | 10:26 AM
mandm1200's Avatar
mandm1200
Are you saying you got the complete center gauge bezel? I'm not worried about cutting into my existing one because I already cut the opening larger about 20 years ago. What I would need is just a trim plate to dress up the look. I'll have to cut the opening and only a small portion of the round holes where the original ***** will be left. A flat plate with two sides will hide the mess.
Old May 9, 2006 | 10:34 AM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Go to www.millionbuy.com They have a bezel that accepts a modern radio for a C3.......10 bucks......looks good.
http://search.store.yahoo.com/cgi-bi...%20by%20Brands
Old May 9, 2006 | 10:59 AM
TonySinclair
I've seen that bezel in other posts...looks good.
How do y'all hold the gauge cluster when cutting? It seems too ackward to hold in a vise. I have a grinder with a cut-off wheel, but trying to get a good position to cut the bezel is keeping me from attempting.
Old May 9, 2006 | 11:30 AM
mandm1200's Avatar
mandm1200
Put your foot on it.
I plan on using a Dremel with a cut of wheel; probably will take a couple of disks to do it. I plan on setting it on a towel. The Dremel is not likely to toss it across the room if it grabs. I'll be cutting mine from the back or at least that is how I think I'll do it. I marked the area with a black marker and will scribe lines to cut and then dress up with a file. I do not believe this metal should be too difficult to cut.
I did get a look at the FP-306 plate. It looks like the same thing I was about to make. It seems it is held in place by the front of the radio. More than likely it can be modded to be fastened to center cluster.
Old May 9, 2006 | 01:29 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Use the fiberglas reinforced cut-off disks. Even better, head down to Ace Hardware, they sell a kit from a different manufacturer that works with Dremel tools. The disks look better than the Dremel disks.
Old May 9, 2006 | 02:50 PM
rosslato's Avatar
rosslato
this is the millionbuy bezel. i used a dremel cutoff wheel and grinder and a file for the perfect fit.
Old May 9, 2006 | 02:55 PM
rosslato's Avatar
rosslato
u just got to keep manuevering the gage cluster in the vice, took me about an hour all total.
Old May 9, 2006 | 03:14 PM
mandm1200's Avatar
mandm1200
Ross:
Thanks for posting the photo of the plate. Having that does wonders and gives it a factory look. It takes awhile to tear things apart and put back together. I didn't want to do a half azz job, especially one that is in plain sight.
Old May 9, 2006 | 04:49 PM
fotyfobravo
Cut the bezel with a high speed dremel with a ROTO ZIP cut bit from Home Depot...the bit cost about 8 clams and cuts like butter. Have your wife hold the bezel, but warn her that it slings melted pot metal everywhere!
Old May 9, 2006 | 05:07 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Are those the Autometer angle rings, or are you the one who cut them out of PVC pipe?
Old May 9, 2006 | 10:25 PM
rosslato's Avatar
rosslato
Old May 9, 2006 | 10:56 PM
TonySinclair
Can I use the cut bit in a ROTO-ZIP to do the job? I already have that set-up.
And, where do you get one of those "wife" things?
To Radio Bezel
Old May 10, 2006 | 05:44 PM
mandm1200's Avatar
mandm1200
Why would you want one of those? Expensive to buy, lots of maintance, nerver works when you need it, and usally only last a few years. Better off renting one for a couple of hours. She hold your bezel and then some!
Old May 10, 2006 | 09:14 PM
TonySinclair
Well...I cut the bezel today. Combination of a cut-off wheel on an angle grinder and a sawzall. Cut nicely, radio fits perfect. Just waiting for the "cover-up" bezel from MillionBuy...
Will post pics when finished.
Thanks all!
TonySinclair
