Brake rotor question?
no you don't need to get new rotors turned once they go on the hubs...although you may want to ensure that the rotors and the hubs have minimal run out once you mate them....there is no reason not to grind and drill the rivets out..... the front and rear rotors are different so if the rotor doesn't fit be wary that they gave you the wrong one...happened to be several times before they got me the correct one, i used the local car quest and other then the wrong box syndrome i was happy with them.
No ... after you drill the rivets ... grind them to the hub surface
and punch them out. Leaving stubs of rivets is no advantage.
They were rivetted from the factory to be turned on the hubs and
hence be totally true in runout. Noone will turn them (that I've heard of)
on the rear hubs. Get rid of the rivets and move on. IMO you made a
good choice with the Raybestos brand .. what I use. 5001s or something like that.
If totally **** (like some of us), you can shim the new rotors to get
near zero runout ... or just rotate through the 5 positions to get
minimum runout without shimming. A couple of my rotors went from
20mils to 2 mils runout after shimming. This ... after installing Oring
calipers to reduce air pumping from runout.
I used soda cans to cut donut shaped shims ... then sanded them down
to the exact thickness needed. Soda cans are about 4mils thick ...
which translates to much more at the edge of the rotor.
Again .. .fairly **** getting it to zero .. but minimum (1 of 5 positions) is recommended.
You can get a magnetic base and dial indicator from places like Harbor Freight for cheap money ($20 total).
