fender height 1/2" difference between left and right?
It's got new springs all around, unfortunately I didn't measure anything before the spring swaps, so I don't know if this was a pre-existing condition or not.
Pat Kunz
Anyway, one thing I found was that the last idiot that had my a-arms apart put the spring in wrong. The end of the spring is supposed to fit in a detent formed in the spring well. It wasn't, there was about 1.5" of spring sitting on the lip of the detent. That has to make a difference in ride height.
My right side sits higher than my left by a little more than an inch. After I finish up, I'm very curious if by putting the spring in correctly, it will fix the uneven ride height.
Another problem I found was that the idiot used a pickle fork and pneumatic hammer to separate the outer bushing sleeve from the a arms. Gouged the heck out of the bearing surface. No wonder it wore out so quickly.
IDIOT argh
Your best post yet.
Jeremy
Jeremy
That will determine one of four things... a level frame, body bushings or bushing mount problems, or frame twist/diamond.
Correct repair for frame twist is frame off and brought to a frame shop.
Correct repair for body bushings is replacement.
Correct repair for body bushing mounts is bending back to factory specs (can be DIY).
All can be "cosmetically overcome" with spring adjustment in the rear...close enough visually.
I have two threads showing on the RR of my 8" spring bolts, and about 3/4" of threads showing on my left...I still have the drivers side 1/4" lower vs. passenger side, which would mean I would still have to tighten the drivers side to get it perfectly even.
For cosmetics adjustments I measured:
top center of each fender lip
leading edge of front nose left and right
trailing edge of rear bumper left and right (inside of bumper stops)
9 leaf rear spring was rebuilt when diff. was rebuilt, and 8" bolts added with poly bushings.
I know my body bushings are dry-rotted, cracked and worn...there possibly could be frame twist...the cosmetic adjusment using the rear spring height will do fine for now.
You will want to drive it here and there after each spring adjustment for the suspension to settle back into the neutral position...sometimes a drive "just around the block" dont cut it enough to measure again and make a decision.
I usually send my son to school in it for two days...the tore up rural roads are sure to settle the suspension by the next time I measure...
Jim
Pat Kunz
Clik here: http://www.vbandp.com/SearchResult.aspx?KeyWords=spacer
Pat Kunz
In my earlier post, I mentioned that I discovered that my right side spring was out of the pocket. Putting it in correctly seems to have pretty much evened out my ride height but....It also seems to have raised it. I would have thought that it would have lowered it but the exact opposite occured.
Cant say as I understand this.
If rubber bushings, then tightening them B4 lowering will preload
the bushings leading to increased ride height and premature bushing failure.
I like poly bushings. They act like a hinge - not twisting like the rubber ones.
So, you can tighten them up B4 mounting them on the car without the concerns of rubber ones.
Regarding the 1" coil spring spacer ... they are hard rubber and can be
"adjusted" in height with some careful cutting and/or sanding.
I have a pair I found on Ebay for $10 ... maybe worth a look.
To add:
When you raise or lower one corner...all corners raise or lower's...though not as drastically.
To understand; lift a yard stick 1" from a surface at the end (36" mark)....take notice of the height at the 6 inch mark.--approx. 1/8"--
then lift the yardstick to 6 inches at the end (36" mark)....now note the new height of the 6" mark.--approx. 1 full inch--
So; putting a 1" spacer will NOT raise just *that* corner (the 1/2" lower corner) and make it 1/2" higher....both sides will raise...so will the rear.
I ALWAYS CHECK:
1>tire height as being the same left to right
2>correct air pressure in all the tires....you'de be suprise how many "weak springs" are due to incorrect tire height or air pressure.
3>springs seated correctly
still un-even?
4>measure frame
5>diagnose problem.
That being said;
If a customer comes to me with a front corner 1/2" lower...I am reaching for a 3/4" spacer.
I dont like doing my work twice...I am usually pretty good at getting it right the first time.
And believe me; I could of taken some "smart" people to the cleaners because of tire size, and/or air pressure!
Oh...and dont even think tires stores dont make a mistake.
Blonde female cousin comes back from Uniroyal that had a n00b...three new 235/70's and one new 225/75 (black-walls).
The alignment guy there said she needed front struts and frame repair to "fix the lean"...
I said she needed four tires the same size.
GL
Jim
I used Poly. Very nice to install.
I think you might be correct--check in the AIM and I believe you will find this to be within acceptable limits. I would guess most Forum members Vettes are a larger difference than 1/2 inch.
SEMPER FI--1970 Dave
