AstroVentilation - 72 A/C Coupe
Old May 10, 2006 | 02:48 PM
kaamacat's Avatar
kaamacat
Default AstroVentilation - 72 A/C Coupe
OK....... can someone explain what actually should (and should not) function with this astro ventilation on an a/c car pleeeeeeeease.
1972, SB, A/C
(I guess ultimately I am wondering should I be getting a flow of air out of the vents with the sticks pulled out?............ which then in-theory would exit the rear deck vents...etc).
BobR
Old May 10, 2006 | 02:56 PM
68435roadster
Guest
Posts: n/a
Bob,
A/c equipped vettes use block off plates over the rear vents. I think there is an "air" selection on your center console that opens the forward vents via vacuum control?
Old May 10, 2006 | 03:00 PM
kaamacat's Avatar
kaamacat
roadster........ Possibly just using the "vent" selection just above heater will do it. (and thanks!). I guess I can always see what it takes to unblock it...........(unless its done already). because I dont detect a pressure build up inside with the windows open. (or I can just close the car up, put on the a/c and watch from outside.......put some light streamers on the vents to see if there is flow...etc
Hey............ thanks again!
Old May 10, 2006 | 11:50 PM
Tom73's Avatar
Tom73
On A/C cars the AstroVent system was non-functional.
What "sticks" are you refering to????
tom...
Old May 11, 2006 | 02:01 AM
Greg's Avatar
Greg
Just another Corvette guy
Tom,
I think kaamacat is referring to the chrome vent ball control ***** at the lower right and left corners of the dash.
Greg
Old May 11, 2006 | 03:51 PM
Flagstaff_Vette's Avatar
Flagstaff_Vette
Can you tell me why A/C Cars have "AstroVentilation" on the side windows then?
Was this a bubba option (Part # BUBBA-0167) - or did the factory do this to my car?
Old May 11, 2006 | 03:56 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It was just a standard inscription on side window glass....ac, non/ac...it didn't matter.
To AstroVentilation - 72 A/C Coupe
