anybody know what circuit this grounds?
it is near the bottom, on the drivers side.
I'm guessing turn signals circuit, since my have been acting up for the last 6 months and this "ground" was not very grounded when I pulled out the radiator and support bracket.
I believe it is ALL front lights and horns - essentially, the front of the car - radiator forward.
cool, thanks for the info.
the recommendation had been "check ground" but I never knew where the ground was. Found it by accident while removing and replacing the radiator & support bracket. Hopefully this will fix my turn signals too...although this is a pretty pricy way to fix a turn signal!
