BB Stock Tires?
Old May 14, 2006 | 10:37 AM
VetteLS6's Avatar
VetteLS6
Default BB Stock Tires?
Ever since I bought this 26 years ago, Ive wondered what it would be like to drive with the factory tires (F70x15 Bias Ply). When the car was bought it had Dunlop Non-DOT Rain tires on it. Even with those it was a bit of fun (454LS6 Rdstr(built Like L88), M22, 3:70). I know the more senior members remember the days....so gentlemen lets get this in writing, just for the good 'ol days and of course to help me out here. When the car gets its frsh paint this summer I was considering getting some vintage rubber from Coker or should I keep the BFG meats on?
Thanks,
Larry
Old May 14, 2006 | 10:52 AM
sxr6's Avatar
sxr6
NO...NO...NO..
Being a "senior" member I remember going from a set of F70-15 Goodyear Polyglass to a set of BFG T/A radials
WHAT a huge ride & traction improvment!!!
The only reason I would ever put a set of bias on my car (except of course for concors show car) would be to spend an afternoon burning them off
If you drive the car even occasionally keep the BFGs
Old May 14, 2006 | 11:26 AM
VetteLS6's Avatar
VetteLS6
Can you be more discriptive in your impressions of what it drove like? I would assume you could probably leave rubber in every gear. Would it leave marks on the highway at 60mph? (Could be a fun factor and make a Mustang/ricer look whimpy)
Thanks,
Larry
Old May 14, 2006 | 11:41 AM
crazywelder's Avatar
crazywelder
Bias ply tires will follow every groove or rut in the road, where radials are more forgiving. Bias plys have a stiffer sidewall which changes cornering behavior, noticably changing the handling. Bias plys have a weaker construction (polyester or nylon belts instead of steel) making them less safe over road hazzards for traveling for instance. Bias plys will wear faster than radials. Bias plys are softer and will give a softer ride. Radials will offer better traction but the difference is not as exagerated as you describe or desire. I grew up with bias plys on these cars and they worked fine, but radials are much better.
Oh yeah, I am not a senior yet, but I do have fond memories of driving this when new on bias plies, and it wasn't traction challenged, and it was good in snow too!
Old May 14, 2006 | 11:52 AM
chevylit's Avatar
chevylit
Bought a 65 425 horse 396 new in 65, biggest tire available was
6:70 /15 bias tread,whitewall of course. Made for some xciting rides,
but thats all there was back then so everyone thought the cars were
supposed to handle like that.
Old May 14, 2006 | 12:07 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
I run my 69BB with either Uniroyal radials or Firestone bias ply repros.
The repros have been on the car for about a year, because I'm too lazy to switch them over. Have the radials mounted on another set of wheels too.
IF you have the correct, original toe in specs on the front end, the bias plys run just fine, NOT as well as the radials, but they don't track in every rut in the road.
The tracking is the result of insufficient toe in in the front end. If you look at the original alignment specs for your car that originally came with bias plys, you'll find a dispartity between that number and the specs for radial tires, which became standard in ~1973'ish.
A few weeks ago, I took a 100+ mile trip in the 69 up to York, PA, then to Carlisle, PA, and then back home. The car ran and tracked just fine. Chuck
Old May 14, 2006 | 03:11 PM
VetteLS6's Avatar
VetteLS6
I guess Im a bit older also,not quite in the senior range though. When I was in High School my sisters Boy Friend drove a 65 396 Vette and from what I remember it would just fry the tires in every gear. I never did get behind the wheel of it. Back in 1973 I drove a friends 390GT Mustang and it would do the same through all 4 gears. I had a 66 GTO YR coded Tripower with 4:10s and that would roast the L60s it had. I guess what Im looking for is how good are BB Vettes with the hipo factory engines and stock tires when driving and taking off...or just jumping on them down the highway?
Larry
Old May 14, 2006 | 04:27 PM
jr9170's Avatar
jr9170
From: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
Keep the BFG tires on.I was going to buy a set of repros for my 70,but i love the ride of my 255/60 radials too much.
Old May 14, 2006 | 10:28 PM
early shark's Avatar
early shark
Larry,
One of my LS-6's rides on original F 70x15 Goodyear Wide Treads, the other LS-6 rides on 255x60 15 radials. The original nylon bias belted tires twist easily with the throttle, the radials bite much better. The bias belted originals don't track very well, squirming over every rut and crack in pavement, the radials are much more smooth and forgiving.
Still want to talk with you about your LS-6, will call you.
Old May 15, 2006 | 12:03 AM
VetteLS6's Avatar
VetteLS6
Sure what would you like to know? PM with number if thats better I cant PM you because your box is full...it happens
Old May 15, 2006 | 04:36 PM
jr9170's Avatar
jr9170
ahoover,I like that picture,what year is that from?...
To BB Stock Tires?
