Front Side Marker - how to?
Old May 16, 2006 | 04:07 PM
el capitan's Avatar
el capitan
5th Gear
Default Front Side Marker - how to?
Hi,
Looked though the forum and not seeing this topic. I need to replace the bulb. Does the front side marker just pull off or does it need to be unscrewed from inside?
Thanks Guys!
Old May 16, 2006 | 05:00 PM
NHvette's Avatar
NHvette
The front side marker has a twist-in bulb holder (small one).
1/4 turn and pull out to remove ... reach back behind the bezel.
2TONE82's Avatar
2TONE82
I think it depends on the year...on my '82 you press a tab on the side and then twist and pull the socket out of the light. The bulb pulls straight out.
Old May 16, 2006 | 05:16 PM
el capitan's Avatar
el capitan
5th Gear
Thanks guys, actually need info on removing the actual marker to get to the bulb.
How do you pull the marker off, mine is a 1979.
Old May 16, 2006 | 07:19 PM
NHvette's Avatar
NHvette
There should be 2 nuts on the back side to remove the entire housing ...
but that won't get the bulb out. Bulb socket twists into back of the marker housing.
Be careful ... the studs are not strong. You breakit, you buy it ... a new one.
To Front Side Marker - how to?
