I am dangerous
Old May 17, 2006 | 01:30 PM
PRNDL's Avatar
PRNDL
Default I am dangerous
I am so non-mechanical sometimes I amaze myself. I can get stuff done, it's just that it doesn't come natural to me.
After spending 2 days wrestling with my p/s pump and belts, and taking off the alternator and putting it all back together twice, I finally half gave up and put it back the best I could (not perfect) and tightened everything down and started the vette up.
1. Immediately the idle was very high, maybe 1500 - 2000 rpm, I punched the gas but couldnt get it down. Pulled off the air cleaner, checked the linkage... it seemed to be returning reluctantly, got back in the car..... pulled the rubber floormat away from the gas pedal ... idle returns to normal.
2. So i don't go for a test drive, but run the engine in the driveway, goose the rpm up to 4000, I still get a little belt squeal but no clatter. Test drive needed later.
So... this morning for some reason I am thinking about the whole job, putting back the p/s pump, belt, generator... and I have NO memory of hooking up the wires to the generator. But I ran the car! Went down and checked... No wires hooked up. Yeah, car can run on battery alone for a while.
Good thing I don't get paid for this... especially by the hour
Old May 17, 2006 | 01:37 PM
mooneyd's Avatar
mooneyd
Cars with the old generator set up can also run without a battery.
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
That sounds like some of the "mechanics" that work on my DD.
My wife does this ALL the time. She'll say "I was driving down the road when all of a sudden the car takes off on me!" Twice already she's pulled off the road and called trying to somehow blame me! She doesn't believe me when I tell her it's her floor mat that she pushed up under the dashboard.
Old May 17, 2006 | 01:39 PM
rihwoods's Avatar
rihwoods
Don't feel bad..at my age CRS has crept in big time...so I make a check list....
Did you check your belts with a straight edge? That's how I solved my problem...my alt/steering belt was off 3/16" pulley to pulley...that put a bind on P/S pump....
Rich
Old May 17, 2006 | 01:44 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Isn't that the truth.
Old May 17, 2006 | 03:26 PM
kevinator80's Avatar
kevinator80
Cars with an alternator will run with out a battery also. Disconnecting the positive cable on the battery with the engine running is a way to test if the alt. is charging.
Old May 17, 2006 | 07:18 PM
Flagstaff_Vette's Avatar
Flagstaff_Vette
Was your name Bubba in a former life?
<just kidding of course>
Old May 17, 2006 | 08:44 PM
Vette Dent's Avatar
Vette Dent
Be careful!! I don't think that you are supposed to do that with the newer computerized cars.
Old May 17, 2006 | 11:20 PM
LemansBlueStingray's Avatar
LemansBlueStingray
You sound like me swapping a T-56 into my Mustang this weekend (yes, I said the Rustang word). I got it all done and then BAM snapped the header stud
To I am dangerous
