Well its back home...
Old May 17, 2006 | 07:57 PM
JustForFun's Avatar
JustForFun
Default Well its back home...
The 81 vert conversion came back from the paint shop. Now i need to finish putting it together. I actually drove it further today then its been driven in 12 years
MAN IT FELT GOOD!!
Old May 17, 2006 | 08:01 PM
jomor's Avatar
jomor
Old May 17, 2006 | 08:32 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Looks great
Old May 17, 2006 | 09:00 PM
Vettkeeper's Avatar
Vettkeeper
Sweet!!!!
Old May 18, 2006 | 06:33 AM
JustForFun's Avatar
JustForFun
worked on it til late last night...im sure tonight will be the same. Man...This is like therapy
Old May 18, 2006 | 06:38 AM
standup's Avatar
standup
That's really cool
Old May 18, 2006 | 08:39 AM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Default post 75 vert
Definitely the car GM SHOULD HAVE built. Awesome job. I can't imagine the kind of work needed to get you to this point so far. Great job!
Old May 18, 2006 | 08:46 AM
GL82TPI's Avatar
GL82TPI
JUstForFun,
The car looks great! Good job!
With the TPI install, where did you mount the ECM?
Old May 18, 2006 | 09:00 AM
JustForFun's Avatar
JustForFun
Originally Posted by GL82TPI
JUstForFun,
Thanks. I mounted it in the cargo compartment behind the pass seat where the jack is
Old May 18, 2006 | 09:21 AM
GL82TPI's Avatar
GL82TPI
Any idea what you are going to do about an air filter? I had to trim about 1/4" off of each fan blade plus trim the rubber boot on the K&N air filter to get mine to fit. I'm planning on installing an electric fan in the near future, but a cold air intake of some sort would be the best solution.
Old May 18, 2006 | 09:51 AM
JustForFun's Avatar
JustForFun
I did the exact same thing. had to trim the fan blade, used a KN filter as you have.
Old May 18, 2006 | 02:50 PM
kevinator80's Avatar
kevinator80
That looks really nice. I hope to start my conversion later this summer. Didn't I read that you used an ACI conversion? I know they sell the deck, but do they also sell the hinges and the lid that raises?
Old May 18, 2006 | 04:53 PM
JustForFun's Avatar
JustForFun
pieces you will need:
Deck lid, drain channels, and floor pans-ACI
Hinges, hinge mounts, deck lid and hardware-Ebay (i just sold a brand new set of hinges for 75 bucks) wish i had kept them
You will need someone and something to mold some pieces to connect door pillars to the decklid. The deck lid is only about 98% complete. you will need to fabricate the remaining pieces.
You will also need some deck panel bracing. We used angle brackets.
Make sure you have a factory vert avail for comparison....this is important
Old May 18, 2006 | 05:13 PM
SULLY_PA's Avatar
SULLY_PA
Looks Great
Old May 18, 2006 | 06:17 PM
JungleCat's Avatar
JungleCat
St. Jude Donor '05 thru '26
Very nice. GM should've definitely continued making C3 verts after 1975.
Old May 18, 2006 | 08:00 PM
JustForFun's Avatar
JustForFun
my biggest hold up at present is trying to find out what year door glass is gonna work. dead in my tracks pretty much until i find this out
Old May 19, 2006 | 09:00 AM
red topless gator's Avatar
red topless gator
:iagree
Love them rubber bumpers, to bad they didnt make more of them verts!...........LT
To Well its back home...
Old May 19, 2006 | 09:07 AM
Dobermann's Avatar
Dobermann
Wish I could see the pics, but the computer I'm on has all images blocked. School computers suck.
Old May 19, 2006 | 09:17 AM
JustForFun's Avatar
JustForFun
actually hope to have it 100% road legal tonight. Installed the lights last night, and hope to finish off the new wiring harnesses tonight
Old May 19, 2006 | 09:27 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
John,
looks good...
