Moroso oil pans
I'm looking to pick up a 6 qt moroso oil pan with a kicked out sump for my 454. Is anyone aware of any clearance issues with these pans?
Specificially I'm looking at this pan
http://www.jegs.com/webapp/wcs/store...chItemId=21101
Also, is the oil pickup required? The sump depth on this pan and the stock pan both appear to be 8".
Also you can try Norval as he has done some pan modifcations and who knows maybe he could throw one together for you.
You might even try a search for oil pan and 427HotRod as he did have a long post about this very question of yours as well.
Here you go Main
http://forums.corvetteforum.com/show...hlight=oil+pan
Guess I caught a case of the noob'sJust found this link as well.
Thanks for the help!
Kicked-out sump design for increased oil capacity. 8'' deep for maximum ground clearance. Trap door baffle keeps oil in the pickup area. Built-in scraper quickly removes oil from rotating assembly and a uni-directional windage tray screen helps it drain into pan. Accepts up to 4.250'' stroke w/steel rods and 4.090'' w/aluminum rods.
Although I used a Melling's M-77 oil pump, the recommended oil pumps are - Stock oil pumps or Moroso BBC race pump P/N 22150 (Std.. volume race), 22160 (High volume race), 22162 (Blueprinted high volume) - Pickup P/N 24440
Bullshark
