No Go Window!!!
Old May 17, 2006 | 10:31 PM
gtsvette's Avatar
gtsvette
Default No Go Window!!!
i had this problem for a long while but never came around to getting it fixed..... my power widow motor will spin but the windows wont move...but the worst part is, the windows can move up and down if you push it with your hands..in addition both windows are shaky and slaps around when i hit a bump.will a torn gear casue this or somthing else?????
Old May 17, 2006 | 10:48 PM
c3dreamer's Avatar
c3dreamer
Problem will be related to a loose gear or a worn gear of the motor. Remove panel and check motor and window glass installation.
Old May 17, 2006 | 10:57 PM
onaqwst's Avatar
onaqwst
u also need the window felt guides...2-3 per side i think..... to help put pressure on the window for side to side vibration
b
Old May 17, 2006 | 11:50 PM
SIXFOOTER's Avatar
SIXFOOTER
Just Do It
http://www.ecklers.com/product.asp?p...dept%5Fid=1673
Old May 18, 2006 | 08:37 AM
1Z87L8's Avatar
1Z87L8
could also be teeth missing on the regulator, thats what my problem was. had a bunch of teeth missing off the very end of the gear and motor would just spin until i pulled up on the window and it caught the good teeth and go up.
Old May 18, 2006 | 11:38 AM
gtsvette's Avatar
gtsvette
ill take apart the door today....
To No Go Window!!!
