Things to look for when purchasing
Old May 19, 2006 | 09:35 AM
'86VetteHead's Avatar
'86VetteHead
Default Things to look for when purchasing
I am going to look at a 77 tomorrow that I am really looking into buying, and I was wondering what types of things I should look out for in that timeframe of the generation. Its a bit over 100K miles, used at a DD for most of its life. The owners I may be purchasing from have only put 60K miles on it in the past 8 years and are looking to use the cash for their children's education.
This will be my first vette, and I want to make sure that it is worth the $7500 the owners are offering.
They say that the whole exhaust was redone, various suspension parts replaced ( A arms and shocks), Battery, and brakes. The tires are 8 years old and have 60K on them. The clock doesnt work, nor the AC, and the E-brake doesnt hold.(I will look to get that fixed,as well as put new tires on it)
I just wanted some opinions and tips before I go out to look at it tomorrow.
Much Thanks.
Sam
Old May 19, 2006 | 09:42 AM
cab's Avatar
cab
from my personal opinion rust, rust, rust. check the frame and around the window pillars. does it need paint, engine solid, interior. all this came be replaced but will cost $$$. if i would have know all this before i bought mine i might have looked for another vette. but lessons learned and pockets emptied. good luck.
Old May 19, 2006 | 09:57 AM
TonySinclair's Avatar
TonySinclair
Are they sending their children to Community College?
Only 60k miles in 8 years? My car has only 64k miles in 32 years. Heck, my DD didn't get 60k in 8 years.
Frame/windshield rust is the big "deal breaker". Also, a lot of the "nickle & dime" stuff adds up REAL quick (ask me how I know)...
A/C doesn't work? How important is having A/C in your climate? That could easily be a $2k repair/upgrade.
For $7500, that car should be near perfect.
Old May 19, 2006 | 10:03 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Scroll down to the Mechanics Inspection Before Buying, parts 1-3
http://wiki.corvettefaq.com/index.ph...e=Misc_Overall
Old May 19, 2006 | 03:29 PM
'86VetteHead
Thanks for the help guys. I really appreciate it. Appearently it had been into a vette shop in town, and i think ill take a run over there later this afternoon to see if they remember it.
Old May 19, 2006 | 04:06 PM
GeorgeZNJ's Avatar
GeorgeZNJ
Look under the car, especially the rear. Mine had/has cracks in the bracket that holds the rear in the car , also if its an automatic, shift from park to drive, if the rear of the car lowers itself this might be an indication of another problem. Ask for a hose, and soak the top of the car to see if the t-tops leak, check under the front carpet for rust from water leaking into the car. I'm not a mechanic and these are the things I should have done 10 years ago when i bought mine.
Old May 19, 2006 | 05:12 PM
'86VetteHead
What happens if the car dropps when it is lowered when you shift? what does that mean?
Old May 19, 2006 | 05:35 PM
NHvette's Avatar
NHvette
Some "squat" when put into drive is normal. Excessive squat is indicative
of a weak rear spring ... not too expensive to solve.
RUST is your #1 enemy here. Steel floorboards - check 'em good.
Frame rot around the end of the rail that terminates in front of the rear wheel.
Look for rust expanding in the trailing arm pockets.
Remove the kick panels and look for rust-through in the area of the body mount here.
Look for rust peeking out around the windshield frame trim.
Reach under and behind the rocker panel trim area. With your
fingers between the frame and the steel rocker channel (unseen),
pull outward on the rocker channel. It should feel solid with very very little flexing.
Unfortunately, the most prevalent rot areas on the frame are mostly
hidden with the body in place. If possible, jack up the vette at the
jack point under the rear of the door. Try to open and close the door.
If door is getting jammed up, this is indicative of a weakened frame
and/or body mount locations.
Any closer inspection would be considered invasive to the owner.
Good luck
Old May 19, 2006 | 06:44 PM
BLUSHRK's Avatar
BLUSHRK
It is sometimes considered to be a "hassle" for the seller, but if they truly have nothing to hide, take the car to a mechanic, preferrably a Vette shop, to have them put it up on a lift. It takes about 20 minutes and anywhere from $50-100, but it's so worth it. The guys at a Vette repair shop will know exactly what to look for that you wouldn't notice. In my opinion it's the smartest investment in your car you could ever make. I looked at one that I thought looked "ok" but it had been in an accident and was REALLY bad. The guys at the Vette repair shop saved me from making a huge mistake.
Old May 19, 2006 | 07:11 PM
c3dreamer's Avatar
c3dreamer
in addition you must check trim plate data and compare exterior and exterior color, VIN, matching motor numbers, rust in windshield and in frame, leaks of water from weather strips, modifications (intake manifold, carburator, valve covers, etc)
To Things to look for when purchasing
