First time poster, question about spinners on 15 " wheel
Old May 22, 2006 | 10:08 AM
Xzap's Avatar
Xzap
Default First time poster, question about spinners on 15 " wheel
Hi everyone, I'm Dave from Winston-Salem, NC.
I have a '79 with 15" aluminum wheels and added a set of spinners over the weekend. They are from Eckler's, the set that comes with the adapters that anchor to the wheel with set screws & then the spinner screws on that with one more set screw to secure it to the adapter.
My question is.. will those adapters have to come off to change a tire ?
The reason I ask is that I've already had one come loose, so I pulled it off by hand before I lost it. I think the problem is the set screws aren't large enough to really get a good grip on the wheel.
Soooo, I was thinking, if the adapter doesn't interfere with taking a tire off and on the wheel, couldn't I spot weld the adapter to the wheel from the back to insure it won't come off?
Thx,
Dave
Old May 22, 2006 | 10:25 AM
MsVetteMan's Avatar
MsVetteMan
That's a joke right? You're not really gonna put spinners on a vette, are you?
Old May 22, 2006 | 10:29 AM
Xzap's Avatar
Xzap
Default Spinners
Uh, yeah.
http://www.ecklers.com/product.asp?p...&dept%5Fid=262
Old May 22, 2006 | 10:34 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
The spinners have to come off to change the tire and balance the wheel.
I have a set of spinners as well, not installed yet because I also think they'll come loose with the supplied set screws.
I'll probably drill a small hole (1/8" diameter, 1/8" deep) in each rim to prevent the spinner from moving outwards even if the setscrew comes loose. There's not much room for a drill inside the hole - a dremel might get the job done... In addition I'll use locktite on the threads
Old May 22, 2006 | 10:47 AM
Xzap's Avatar
Xzap
Thanks Red, will the adapter have to come off also to change a tire ?
If not, I can just screw off the spinner itself and leave the adapter on.
I too was thinking of drilling a small indention in the wheel for the set screw to anchor to.
Thx,
Dave
Old May 22, 2006 | 10:53 AM
panchop's Avatar
panchop
The adapter stays on. The spinner will probably have to come of. I use clear silicon liberaly spread inside the threads on the spinner. Twist the sucker TIGHT, then set the set screw. i haven't had any problems yet.
Old May 22, 2006 | 11:00 AM
Xzap's Avatar
Xzap
Thanks Pan.. I think I'll actually spot weld the adapters onto the wheel.
The spinners are actually well designed as far as how they attach, it's the adapters that aren't quite up to speed.
Thanks for the help guys !
dave
Old May 22, 2006 | 11:05 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Thx,
Dave
It will have to come off so they can mount the rim on their machine to change the tire and balance.... if they could leave it on they would manage to damage it anyways
Old May 22, 2006 | 11:07 AM
kdf1986's Avatar
kdf1986
Hello,
I bought a 1975 earlier this year that had spinners on the wheels already. I found that I do have to either remove the spinner, or at least loosen it up in order to get to my lug nuts.
You can see in this photo that one of the lug nuts is behind the spinner itself.
kdf
Old May 22, 2006 | 11:32 AM
E_Tar's Avatar
E_Tar
Don't spot weld. use JB (thin coat on the inside of the center rim. It will hold those center cones on tight. the spinner caps will come off, so you can change tires etc... make sure to use one screw to keep the spinner cap on tight and to dissuade creeps who like to steal.
I JB'd mine..
Old May 22, 2006 | 12:15 PM
PRNDL's Avatar
PRNDL
I thought those things were called "knock offs"
When I saw your topic title I was afraid you meant these:
Old May 22, 2006 | 12:32 PM
Xzap's Avatar
Xzap
I've always called them "knock offs" myself
Thx,
Dave
Old May 22, 2006 | 12:57 PM
2TONE82's Avatar
2TONE82
whew, I thought you were talking about the "bling-bling" spinners as well... I'm OK now, knock-offs are cool
Old May 22, 2006 | 01:10 PM
454_71Stingray's Avatar
454_71Stingray
How about some loctite? the blue is not as strong as the red but it should work without having to drill. Just a suggestion.
Old May 22, 2006 | 02:31 PM
icanfixitforyou's Avatar
icanfixitforyou
Hey Msvetteman - I don't think that he is talking about "spinner" hubcaps, if that is what you were thinking of. I believe he is referring to the "knock off" style spinners that you saw on a lot of C-2's. I have the swept fin spinners on my 79 vette with the stock aluminum mags. And no, they don't keep spinning after the car stops....
But I am gonna get one of those little little dogs whose head bobbles around and whose eyes light up when I step on the brakes!
Old May 22, 2006 | 04:19 PM
MsVetteMan's Avatar
MsVetteMan
whewwwww......I thought we had a lost one on our hands.....lol.....
Spin on my brother.......
Old May 22, 2006 | 04:33 PM
Xzap's Avatar
Xzap
I have a young (25) girl that I work with.. I mentioned to her the other day I was gonna put spinners on the Vette. She said she wanted some for her car too, which is an old Mazda something.
I'm like WTF ? Then she tells me what "spinners" are
I've always called them knock offs, now I call them a PITA.
Thanks for all the ideas guys. I'll let ya'll know what I come up with and how it works out.
BTW, great forum
Dave
To First time poster, question about spinners on 15 " wheel
Old May 22, 2006 | 05:41 PM
Sprzout's Avatar
Sprzout
Thank god you were talking about Knock offs...
The "bling bling" spinner rims belong on ricer vehicles, or SUVs of rappers with more money than common sense.
Old May 22, 2006 | 09:22 PM
offaxis's Avatar
offaxis
I went with the silicon glue and stay off real bumpy roads
ps I have lost 2 so far, so I would get a extra set just so if you need them next time you got em, looks real wierd with one missing, you think that's what everyone is looking at.....
Old May 23, 2006 | 08:37 AM
mooneyd's Avatar
mooneyd
