lacquer paint
Old May 22, 2006 | 01:35 PM
toupstrio's Avatar
toupstrio
Default lacquer paint
Does anyone know if you can still buy lacquer paint anywhere? I mean does PPG,House of Kolor or BASF still make it? I would like to try a project using this paint Im trying to get a real deep look maybe something else is better if you know of something please pass it on.
Old May 22, 2006 | 01:44 PM
Niart01's Avatar
Niart01
Default lacquer Paint
I painted my 73 last year and used acrylic lacquer. I came out fine, but when I need to repaint it I will use basecoat/clearcoat. It is much more durable and if you color sand and buff you will get just as nice a job. You can still buy lacquer here in Chicago, but it may not be here for long. I think I would go the 2 pack route. Just my 2cents worth.
Portage auto supply in Chicago.
Old May 22, 2006 | 02:03 PM
toupstrio's Avatar
toupstrio
Thanks for the advice I did not realize I could sand the base coat clear coat to give it more depth.
Old May 22, 2006 | 02:43 PM
bashcraft's Avatar
bashcraft
You can still buy it in PA.
Old May 22, 2006 | 03:01 PM
crazywelder's Avatar
crazywelder
PPG still sells lacquer in Detroit. It's probably time to change over and learn the newer paints. They really are easier, faster and more durable than lacquer. As said earlier, you can still wet sand and buff to get an incredible finish. Application and paint flow is similar to older enamels and might take some practice to perfect. Dry time is slower, so cleanliness is a must if not using a booth.
Old May 22, 2006 | 03:19 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I just bought a gallon of PPG Duracryl '77 corvette bright yellow lacquer from these guys. They can mix any old system formula
http://www.ppgcarpaint.com/
Old May 22, 2006 | 04:25 PM
CGGorman's Avatar
CGGorman
I've got a quart of International Blue that's almost 30 years old.
Old May 22, 2006 | 07:36 PM
crazywelder
Mr. Gorman, I guess all of us middle age lacquer guys have some old paint lying around!
Old May 22, 2006 | 10:01 PM
CF6873's Avatar
CF6873
Lacquer was much better in those days. In the 80's they eliminated lead from the chemistry and the paint was not as durable.
In my opinion urethane clearcoat is the only way to go.
Old May 22, 2006 | 10:13 PM
toupstrio's Avatar
toupstrio
Yes it seems I will go the base coat clear coat can someone guide me in the right direction for the brand ? etc? any tips?
Old May 22, 2006 | 11:09 PM
BarryK's Avatar
BarryK
PPG is the only manufacturer of lacquer anymore that I'm aware of but as mentioned it's not the same as the "old" lacquer since they removed the lead out of it.
BC/CC makes more sense nowadays if you plan on actually driving the car rather than keeping it as a trailer queen that never gets used.
yes, BC/CC can be wetsanded and it comes out looking great!
My '65 was just repainted last year and it was done with 2 coats of base color, wetsanded, followed by two more coats of base color, than 4 coats of clear and wetsanded and buffed out to a beautiful shine.
if your paint is a metallic you do NOT want to wetsand the final coats of base before you clearcoat it or it messes up the way the metaalic appears since the metallic is lighter than the rest of the base paint it tend to rise to the surface and you mess it up if you wetsand it before clear coating it.
Old May 23, 2006 | 02:09 AM
Skid*MARK's Avatar
Skid*MARK
Calvin, the Pro Mod Camaro that you saw in my shop when you got the carpet from me was a PPG Base /Clear job that was sanded and buffed right there in the shop where it sat.
I will have to get some pic of it outside in the sun, now that it is almost back together and has had all the art work air brushed on it, it gives the car a whole new look.
Mark G.
Old May 23, 2006 | 06:49 AM
bashcraft's Avatar
bashcraft
My brother has a 66 GTO and he just had it painted black with BC/CC. It looks as good if not better than any lacquer job I've ever seen.
Old May 23, 2006 | 03:59 PM
toupstrio's Avatar
toupstrio
Mark G.
Thanks Mark that paint was beautiful I think I will go that route thanks to everyone who replied.
To lacquer paint
