Question about gelcoat
Old May 22, 2006 | 09:02 PM
Crab's Avatar
Crab
Default Question about gelcoat
I'm having my car stripped and painted. My body man says that it does'nt look like there is a gelcoat on my 1980. My question is when did they stop using the gelcoat and why? Also would there be any advantage to using a gelcoat?
Old May 22, 2006 | 09:12 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
I don't believe gel coat has been used since 1955? The first year press-molded body panels were used.
Old May 22, 2006 | 09:14 PM
SIXFOOTER's Avatar
SIXFOOTER
yep, PMC means no gelcoat, if your bodyman don't nkow this, why is he about to paint your vette?
Old May 22, 2006 | 09:15 PM
BarryK's Avatar
BarryK
they never stopped using gelcoat simply because they never started using it!
Corvette bodies have never left the factory with gelcoat.
There isn't any real reason to use it or need to use gelcoat unless your body has been severly damaged such as from being expose to the elements for many, many years without paint and moisture has gotten in the 'glass or the body was improperly media blasted and you were left with a "fuzzy" fiberglass end result.
for painting, make any required body repairs to fix cracks, etc., than prime it to block sand, seal it, and paint it.
Old May 22, 2006 | 09:18 PM
BarryK's Avatar
BarryK
good point!! painting vettes is pretty much a "speciality" to do it right and if he isn't familar with the fiberglass bodies of vettes than you should be taking your car elsewhere! just the fact that he is surprised to not see gelcoats tells you plenty that he hasn't done any, or very few corvettes
Old May 22, 2006 | 09:33 PM
Crab's Avatar
Crab
He worked for a local chevy dealer for 10 years and made many repairs to corvettes. He had never painted a vette from the 80's. His PPG supplier suggested that there would be gelcoat on my 80 and that it should be stripped then re-applied with a gelcoat from Eckler's.
Old May 22, 2006 | 09:37 PM
BarryK's Avatar
BarryK
well, if he worked on vette at a Chevy dealer than he should have known they don't have gelcoat.
In either case, your car never had it and unless you have MAJOR body damage you don't need it.
Old May 22, 2006 | 10:17 PM
big_G's Avatar
big_G
Old May 22, 2006 | 10:57 PM
Crab's Avatar
Crab
As I said earlier, he never worked on anything this old at the dealer. The PPG rep is where his info came from. The PPG rep is going to guarantee the labor and materials if their guidelines are followed step by step, and one of the steps is a gelcoat by Ecklers.
Old May 22, 2006 | 11:03 PM
BarryK's Avatar
BarryK
well, do what you feel most comfortable with but it's not needed and after putting Gelcoat on it involves a lot of additional labor (read as $$$) to sand that stuff smooth.
I had my '65 painted last year and my '78 is about to go into the paint shop and gelcoat isn't being used and my painter uses PPG products exclusively.
I just can't see any possible reason for needing to use it if your fiberglass isn't damaged severly.
Good luck and enjoy your new paintjob when it's done
Old May 22, 2006 | 11:09 PM
Crab's Avatar
Crab
Thanks for all the info, it's been helpful to me. I just talked to my painter and he spoke to Eckler's this evening and they confirmed that there is NO gelcoat on my car. They sell the stuff for cars that have body damage as you guys stated earlier, Thanks everyone
Old May 22, 2006 | 11:56 PM
rihwoods's Avatar
rihwoods
Worse source: A saleman (rep)...
Old May 23, 2006 | 01:12 AM
Sprzout's Avatar
Sprzout
Along those lines, then...
I'm going to be patching the hole where my power antenna was (filling in the hole and cracking around it) and replacing it with another "hidden" antenna.
Should I use gelcoat to fill in a hole like that?
Old May 23, 2006 | 02:30 AM
livin's Avatar
livin
Everything said here is correct, of course it is... BarryK is on the case. Hi BarrY
The reason there is so much confusion is because when the panels were molded. The female panels were sprayed with a spray release. When the molds were pressed together, the heat created what LOOKS like a gel-coat on the surface of the panel. Still like Barry said there was not a gel-coat.
Some people use a gel-coat regardless of prior damage just to make the body work much better than it was when it left the factory. Of course it may not be correct.... but it will make your finished product will look better and last longer.
Old May 23, 2006 | 11:29 AM
NHvette's Avatar
NHvette
No, use matte glass and polyester resin for this ... grind out a shallow
bevel around the hole and over lap in layers to get a good cover.
Gel coat as stated is just to smooth over rough protruding fibers.
Old May 23, 2006 | 01:20 PM
Sprzout's Avatar
Sprzout
Good, just what I thought. My dad claims to have done a lot of work with fiberglass when he was younger, but it seems more like his experience with it was in attic insulation, not auto body work.
Old May 23, 2006 | 01:46 PM
mkflanagan's Avatar
mkflanagan
Gelcoat is for boats not vettes,they never had it an never will.find another body man.
To Question about gelcoat
