Offset trailing arm problem
Old May 22, 2006 | 10:32 PM
CoolShark's Avatar
CoolShark
Default Offset trailing arm problem
My 72 had offset trailing arms when I got it, but no parking brake. Although the shoes, etc are in, the rear cable is not and there is only the rear guides for the cable on them. I want to weld the front ones on them, but am having trouble with placement. Does anyone have them with photos of how the cable is run?
Old May 22, 2006 | 11:57 PM
chris73cpe's Avatar
chris73cpe
these are only the stockers, but will hopefully give you an idea
Old May 23, 2006 | 12:46 AM
84rzv500r's Avatar
84rzv500r
I have a set of Van Steels that are ready to bolt on the car. If you dont get a Pic PM/email me and I can post/email pics tomorrow after supper EST.
Old May 23, 2006 | 02:10 AM
wnjlt1's Avatar
wnjlt1
van steel offset ta's
drivers side
passenger side
let me know if you need more
Old May 23, 2006 | 12:07 PM
CoolShark's Avatar
CoolShark
Thanks for the info.
Old May 23, 2006 | 03:26 PM
silverslashstreak's Avatar
silverslashstreak
How do you clear the rear spring with the wheel? And what about the rear sway bar getting into the tire?
Thanks SSS
Old May 23, 2006 | 03:31 PM
NHvette's Avatar
NHvette
People used to shorten their springs ... now you can buy them shortened.
Guldstrand has a shortened main leaf they sell. Also, I think VanSteel
carries a shortened spring.
For the sway bar, you can bend the end inward to try and clear the wheel,
or do without a rear swaybar.
I guess you could make a custom one with the splined bars and bolt-on ends.
To Offset trailing arm problem
