Build sheet
Old May 23, 2006 | 09:01 PM
Tongari69y's Avatar
Tongari69y
Default Build sheet
Hi, Dear all 69 funs.
I bought 1969 corvette conv #14679S708441 on Jun-2003 at Tokyo Japan.
My car is not numbers match, transmission and engine want to know in which specification line off was done.
Might build sheet at that time be able to be issued from VIN of my car by asking the organization somewhere?
Please let me know when there is someone understanding.
Thanks,
Old May 23, 2006 | 09:44 PM
PRNDL's Avatar
PRNDL
I think I understand you, because your question is asked very often! Unfortunately there are no records available from which you can recover your buildsheet information. The only exception that I know of is if your car was originally built for export to Canada, GM Canada has records of all those vehicles. I sent my vin to GM Canada and unfortunately all i got back was a letter stating that my car was NOT originally built for Canada.
If you could find a previous owner you might be able to trace the ownership backwards to someone who knows about the car or even has records, but it would require a lot of detective work.
also, you left out a number... you wrote
14679S708441
should be, 194679S708441
Old May 23, 2006 | 10:00 PM
LittleJake's Avatar
LittleJake
Quote:
14679S708441
Hey PRNDL your going to freak the guy out lol. He is going to wonder how you figured out the missing number was 9. lol
Old May 23, 2006 | 11:37 PM
Tongari69y's Avatar
Tongari69y
Default Re:Build sheet
To PRNDL and LittleJake.
Thank you for quickly response.
All content that you had written became reference very much.
I will send email to CANADA GM.
Also,I made mistake about VIN #14679S708441--->194679S708441.
Thanks,
Old May 24, 2006 | 09:07 AM
GUSTO14's Avatar
GUSTO14
Thanks,
Tongari,
I believe there is a Corvette Club of Japan. I know there was one in the Tokyo area when I lived in Japan in the 1990's. (40km south of Hiroshima...) http://www.corvette-club.jp/
These folks might be a great source of local information on your Corvette.
One thing to keep in mind is that when a Corvette is shipped to Japan, the year of the vehicle changes to the current year. If someone brought a 1969 Corvette to Japan in 1975, it would be registered as a 1975. This can be confusing so you probably should establish the actual year of the vehicle as soon as possible. A friend in Otake invited me to come by and look at his 1988 Corvette. When I went to look at it, it turns out it was really a 1984.
Good luck... GUSTO
Old May 24, 2006 | 10:11 AM
Tongari69y's Avatar
Tongari69y
GUSTO14,
Thank you for your response.
I know that corvette club of japan and international shipping matter.
My car's Vechle Identify Number is 194679S708441,
It has been line out on 1968y thru 1969y.There is 8,441st of year 1969 model corvette.My corvette has 350 engine and 4sp manual transmission now.
I want to know original engine(base or L46) and transmission(A/T or M/T) of line out day.
Do you know a way to extermine of "built data" exept VIN?
also,Engine casting number(right hand of engine) is shaved and put on Japanese registration number by japanese ministry of transport.
Thanks,
Old May 24, 2006 | 10:49 AM
rihwoods's Avatar
rihwoods
Best way is to trace that 69 Vette back to original owner..this means you must contact local/state or Canadian Department of Motor Vehicles....very time consuming....fees may be required...many phone calls,as well...
Good luck
Old May 24, 2006 | 10:53 AM
LittleJake's Avatar
LittleJake
Aint that a BIATCH! I bet the NCRS guys have a fit over that one.
Good luck on your car, post some pics when you can.
GUSTO14's Avatar
GUSTO14
Tongari...
The factory did attach a vehicle build sheet to the top of the gas tank. Many of them are still there. Unfortunately after all these years it is probably in very poor condition... if it is still there. You might be able to remove the rubber boot around the gas filler neck and using a flashlight, look at the top of the gas tank. If you do see the build sheet, it might be worth dropping the gas tank to remove it or at least examine it.
I was able to remove one from my 1973, back in 1991 and it was barely legible even then. If you do find the build sheet, dust it off with a gentle brush and take some high quality digital photos of it before you try to remove it.
Keep in mind that 1969 production was one of the larger production runs for the early Shark cars. Based on what you have described, it appears you have a very common 1969 Corvette. That is the bad news, the good news is that all of them were great cars...
Good luck... GUSTO
Old May 24, 2006 | 10:56 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Check the top of your gas tank for the build sheet...it still might be there.
Old May 24, 2006 | 02:59 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the time/build date on the trim tag. You should find a D and possibly D22 for Friday, November 22, 1968. My Corvette Blackbook and a pertpetual calendar tend to show your car was on the assembly line Friday, November 22, 1968 when the trim tag was attached. It would not have been a completed car on that date, but close. The actual date might vary since I'm not sure whether the plant would have been closed two days for Thanksgiving, or only one.
You may or may not find the tank sticker and what you might find may not be legible or complete if anything remains. Copies of build sheets have been found in the wiring behind the speedo and tach; in the wiring behind the center cluster, behind either kick panel, tucked in the springs on the underside of a seat, and under the carpet in the rear storage area. If you're lucky, you might find something.
There is no way to determine the original equipment installed on your Corvette through the VIN unless (as stated) it happened to go to Canada.
Good luck with the hunt.
Old May 24, 2006 | 08:49 PM
Tongari69y's Avatar
Tongari69y
Default Build sheet
Thanks for all 69 funs in this thred.
I was surprised at details about everybody.
I will check top of the gas tank.
I looking forward it still there.
Thanks,
Chihiro
Old May 25, 2006 | 08:35 PM
Tongari69y's Avatar
Tongari69y
Default Top of the gas tank
I checked the top of the gas tank in yesterday night, but I was not able to get the build sheet
also, I checked behind the meter panel, under seat and both side kick panel, but nothing was found...
Just I collect necessary information for time to do frame off restoration of this car sometime.
I don't know how to thank you
Old May 25, 2006 | 10:30 PM
Flagstaff_Vette's Avatar
Flagstaff_Vette
Is it Right hand Drive or Left Hand drive? Pictures?
Old May 25, 2006 | 11:25 PM
Tongari69y's Avatar
Tongari69y
71_454_Green_Machine,
It is left hand drive.
Thanks,
Old May 26, 2006 | 05:05 AM
hunt4cleanair's Avatar
hunt4cleanair
Hey Tong...
Here's a link to an article I wrote and had published in the NCRS Corvette Restorer
C3 Build Sheets
Old May 26, 2006 | 08:54 AM
Tongari69y's Avatar
Tongari69y
hunt4cleanair,
I would like to get the Build sheets of my corvette.....
Though I looked for it, all the places thought about are found nowhere.
Thanks,
To Build sheet
