Getting build sheet read
Old May 25, 2006 | 10:32 AM
b_critical's Avatar
b_critical
Cruising
Default Getting build sheet read
I have a build sheet for my 69 Conv. 427 car. I can read some of the items on the build sheet, but because it was the one above the tank some stuff is very tough. So Does anyone know a company that can read these properly and certify there finding and then put the old sheet into some protective covering so it doesn't get more damage and then make me a new one showing the findings maybe certifing that it a reproduction from the actually finding from the orginal.
Bill
Old May 25, 2006 | 10:38 AM
mensch53's Avatar
mensch53
I would scan a very hi-res version of it and post it to the forum. I bet the guys here could decypher it.
Old May 25, 2006 | 10:47 AM
b_critical's Avatar
b_critical
Cruising
I will do that but it is in multiple pieces and even has dirt stuck to it and I am a little afraid to start wiping all the dirt off since its so fragile 37 years old and all.
I am sure if they I could read it I could dicypher it well most of it anyway. I am thinking that it might need some sort of CSI style equipment to read what can't be seen wit the naked eye. This paper was printed on using a typewriter style head I believe so the might be able to pick up the impression that I can't see.
Bill
Old May 25, 2006 | 11:25 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I had the same problem. Be careful the ink is very delicate at this point. Don't brush it, etc. Put in protective sheet covers. What I did was take photocopies at various intensitites and magnifications. I then compare it to the known option list and was able to decipher it. The copies will help you preserve what you have as well. These are very delicate documents and while GM and some others believe there are copies somewhere in the bowels of GM, no one has found them yet. Good luck!
Old May 25, 2006 | 11:47 AM
68/70Vette's Avatar
68/70Vette
A recent Corvette Restorer magazine had an article about reading faded dirty build sheets. I think they recommended taking a photo with an infra red sensitive camera. Don't take my word though, just try to get a copy of the magazine article. As I remember the guy had a virtually unreadable build sheet, and he was able to get a clear pricture.
To chase down the Restorer, start at NCRS.org.
Old May 25, 2006 | 11:51 AM
DZRick's Avatar
DZRick
Take some photos of it too!!
Both digital and film, just so you've got them for your records.
I found my buildsheet in about the same condition as yours, I was able to use a fine brush to remove alot of the crude and was able to read a good portion of it. I then stored it in a drawer in my garage where it ended up becoming building material for some friggin mice.
Thankfully I wrote down all the info. I could but this no proof to anyone
Google document restoration, should give you some good ideas and maybe point you in the right direction.
I seem to remember something about soaking paper towels in ether and laying the buildsheet between them, but check for yourself.
Goodluck,
Rick
Old May 25, 2006 | 12:53 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 68/70Vette
....an infra red sensitive camera.....
Uh-huh. I've got three or four of those lying around somewhere.....
Old May 25, 2006 | 01:52 PM
72LS1Vette's Avatar
72LS1Vette
Bill
Don't brush it! I did that to mine and found blank grey paper underneath. The infrared photo is something I read about before. If you have a digital camera with Night Shot capability or something similar you can use it to get your photo.
Rick B.
Old May 25, 2006 | 02:17 PM
68/70Vette's Avatar
68/70Vette
Actually, if you read the small print that comes with digital cameras, you can see that some of them are sensitive in the near visual infra red range. Some of the video cams are also advertised as being able to respond to the near visual infra red range also. These capabilities aren't usually given primary advertisement. This infra-red capability helps with low light level photography.
Anyhow, the suggestion to use infra-red was originated by the person who was able to "read" his build sheet. Maybe it was a idea, but it was successful. Once again, the infra-red suggestion was in an article in the Corvette Restorer, it wasn't my idea.
Old May 25, 2006 | 02:29 PM
SIXFOOTER's Avatar
SIXFOOTER
you can get a roll of infra red film for yoour normal 35mm camera at most any camera store, Wolf, Ritz, etc..
Old May 25, 2006 | 02:41 PM
b_critical's Avatar
b_critical
Cruising
What I really want to do is have an expert do it someone who has done this many times. There has to be a source for this. I mean yea I can try but what I want is somebody that can do it they certify it is correct. So there is no question what can on the car orginally.
Old May 25, 2006 | 06:43 PM
jomor's Avatar
jomor
I'm sure there are many experts that will provide that service for you at a price. I would think that level of certification would be Bloomington NCRS or the like, as you seem to need an infallible level of expertise. Most of us here are content (read poor, dirty and/or crazy) to take the posted word of our resident "elders" as good enough!
To Getting build sheet read
