Squeaky Breaks
Old May 25, 2006 | 02:22 PM
VETTEROOKIE75's Avatar
VETTEROOKIE75
Default Squeaky Breaks
HI ALL,
I AM HAVING A PROBLEM WITH SQUEAKY BREAKS. I PULLED OFF THE WHEELS AND THE PADS AND ROTORS ARE FINE. ANY SUGGESTIONS ON WHAT IS CAUSING THE SQUEAKS. I AM ABOUT TO CHANGE BOTH PADS AND ROTORS. I CAN TAKE IT ANYMORE!!!!!
Old May 25, 2006 | 02:27 PM
mensch53's Avatar
mensch53
you might try some of this...
http://www.partsamerica.com/ProductD...rtnumber=80729
Old May 25, 2006 | 04:04 PM
TXredc3's Avatar
TXredc3
Try putting on some softer pads......organic maybe. Won't stop quite as well but I doubt you'll ever know the difference unless you're racing it.
Old May 25, 2006 | 04:10 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I had terrible squeek/squeal untill I replaced my pads and went with an organic set from Muskegon Brake. I can't tell any difference in stopping power. They may not last as long but that's not an issue for me.
1 - [] 1965-1982 FRONT AND REAR BRAKE PADS ( PREMIUM ORGANIC (AIMCO) SPF8S ) - $33.50 USD
Old May 25, 2006 | 04:17 PM
Sprzout's Avatar
Sprzout
Put some anti-squeal on the back of the brake pads, and spray some disc cleaner on the rotors. I was getting horrible squeal with my dad's truck when we replaced the pads; we had to pull the pads back off and apply the anti-squeal twice before it went away.
Part of the reason it squealed after we applied it the 1st time was that we didn't let the anti-squeal gunk set up like it says on the back of the bottle and tried to rush it.
On my DD, I got some squeal initially when I first changed the pads, and that was due to the pads having a "conditioning" layer on them that had to set on the discs themselves. Once I got them worn down past the conditioning layer, they didn't squeal anymore.
Old May 25, 2006 | 04:39 PM
VETTEROOKIE75
Thanks For The Help.....
To Squeaky Breaks
