Fiber Optics
Old May 26, 2006 | 11:33 PM
427-390's Avatar
427-390
Default Fiber Optics
How are the fiber optics on my '68 supposed to operate? Do they only work when a light is out? I read somewhere that when you shut the car down, the fiber optics go through a sort of a shutdown sequence. Is this true? If they are not working like they are supposed to, where to start in diagnosing?
Thanks,
Tony
Old May 26, 2006 | 11:49 PM
big_G's Avatar
big_G
Thanks,
Tony
They pick up light from the bulb. Each of the headlights and the parking/turn/brake/license have a dedicated fiber bundle in the wiring harness. These fiber cables run all the way to the console. No light from the display lens means the light is off or burned out. No shut-down sequence...lol. If they don't work, make sure the fiber ends aren't painted over. Then make sure they are plugged into the lenses on the shifter console. The cables are fairly delicate, and if pulled on, the strands will break. The individual strands are almost invisible, they are much thinner than a human hair.
Old May 27, 2006 | 12:09 AM
427-390's Avatar
427-390
Thanks big_G,
I'll check again, but I thought I did see the fiber optics faintly lit up when I did turn on the headlights. It could be that the coloring on the lens has faded, I won't know until I dig into it a little bit more. I will be restoring/repairing/cleaning the console in the near future, so thanks for warning me on the connections that go to console part of the fiber optics. I don't want to do any more damage then necessary. Much appreciated.
Tony
Old May 27, 2006 | 12:10 AM
big_G's Avatar
big_G
YVW
Old May 27, 2006 | 12:52 AM
James B's Avatar
James B
THat sounds really cool, I wish 73s had the fiber optics. Didnt they stop in 71? I dont remember exactly
Old May 27, 2006 | 12:57 AM
rdog's Avatar
rdog
Fiber optics are fairly easy to replace and are pretty inexpensive. Easy to troubleshoot. For me it is easier to just replace the optics and/or the bundle. Like to play it safe.
Old May 27, 2006 | 02:38 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Yes, 71 was the last year....in place of them the alarm became standard in 72.
Old May 28, 2006 | 12:52 AM
68 NJConv 454's Avatar
68 NJConv 454
Where you getting these so called "bundles"?
Don't recall seeing just the fiber optics for sale, I need to replace all of mine. It is a cool concept. Kudos to GM.
-B
Old May 28, 2006 | 12:54 AM
LittleJake's Avatar
LittleJake
Man im glad my 72 doesnt have fiber optics. I have read so many horror stories about them not working correctly.
Old May 28, 2006 | 01:28 AM
rdog's Avatar
rdog
What I meant by bundle(s) was the wiring harness. The indicator lens is a separate item which is fairly cheap also.
Old May 28, 2006 | 01:30 AM
Matt O's Avatar
Matt O
The fiber optics on my 69 work fine. Just make sure the ends are clean and in place....
Old May 28, 2006 | 01:32 AM
another-user's Avatar
another-user
same thing on my 69. there one of the few things that still works well after sitting for all these years.
Old May 28, 2006 | 09:16 AM
early shark's Avatar
early shark
The fiber optic feature is really neat. At night the center console lights up with all those different colors, reminds me of an aircraft cockpit. I love it!!!
Old May 28, 2006 | 09:44 AM
Rich427's Avatar
Rich427
There is nothing mechanical or electrical about fiber optics. They are very simple. Just fiber strands that transmit light very easily, from the light source to the individual lenses in the console. The purpose of these items was to show the driver if there was an external light bulb that was not functioning.
Here are a few of the common reasons why a fiber optic does not work. Check to see if the bulb is burnt out. If the lights were removed to have the car repainted, it is not uncommon for the fiber optic end to get painted over and not allow light to travel to the console. The fiber cable could be broken as a result of a previous accident. Check inside the console to see if the fiber optic cable is connected to the console lenses. When I first got my car, I found some of the cables just not connected to the console lense.
Anyway, this is very basic technology and it is not like trying to run down an electrical problem. As was previously stated, if you have a problem it is pretty easy to just re-run new fiber cable and re-tape it into the harness. IMO.
Old May 28, 2006 | 01:23 PM
427-390's Avatar
427-390
I was able to check into all of my fiber optics last night and it appears that at a minimum, I'll need to check out 1 of the indicator lights. Not too bad considering the age of the car. I'll get the lenses replaced and check all the connections when I disassemble the console. As stated in a few of the comments, the fiber optics are cool. Thanks to Rich427, big_G, and rdog, for your tips and guidance. Very much appreciated!
Tony
Old May 28, 2006 | 01:43 PM
Maui's Avatar
Maui
St. Jude Donor '08
My 1968 Camaro RS has fiber optics. I am restoring the car right now. They are quite simple except for keeping them snugly in place. They're bascially a piece of thick fishing line.
Old May 29, 2006 | 01:42 PM
427-390's Avatar
427-390
Update:
I got the console apart and it appears that one of the fiber optics was plugged into the wrong location on the lens and the other one was just hanging, not plugged into anything. When I tried to correct the location of the fiber optics in the lens area, I cracked and broke (oops!) the plug in location on the lens for the right rear tail lamp. Good thing I didn't order all of my parts yet. I'll just add this to the list. It probably wouldn't hurt to order either a repair kit or a new harness for the rear tail lamps and license plate lights as one of the fiber optic wires insulation was cracked and exposed (electrical tape is on it now). Thanks again to everyone for all the help and information on this.
Tony
To Fiber Optics
