gauge bezel question
Old May 30, 2006 | 01:50 PM
Archgator's Avatar
Archgator
Default gauge bezel question
I'm going to replace the gauge bezel to install a new CD radio, and my question is does the bezel come off without all the gauges and related wiring? Or is the bezel mounted in front of the gauges and they are attached to some frame behind? I hope the second is the case!!
Old May 30, 2006 | 01:52 PM
1mollyd's Avatar
1mollyd
In my '69 the gauges are fastened to the backside of the center bezel.
Dave
Old May 30, 2006 | 02:02 PM
LABulldog's Avatar
LABulldog
The instrument cluster is connected to the back of the bezel with 4 screws (at least on my '80). It is highly recommended not to cut on your original bezel if you can avoid it due to its originality! Buy you an aftermarket bezel and cut it. Bezels run from roughly $75 to $100 for the later model C3's. I can't speak for the earlier ones. You can buy bezels already set-up for DIN type radios but they run roughly $200 ea. I cut my aftermarket bezel with a dremel and a fine hacksaw blade after measuring everything at least twice. Good luck with it and welcome to the forum.
Jay
Old May 30, 2006 | 02:19 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Gauges are mounted to the bezel from behind. If you pull the bezel, you should expect all of it to come out together. Ditto for the stock stereo; it mounts to the bezel, but from the front. Go slowly. There is apt to be lots of things to unplug and unfasten.
Old May 30, 2006 | 03:13 PM
Archgator's Avatar
Archgator
Thanks for the input, I was hoping the gauges were not attached to make it easier.
Any chance a '72 is different??
Old May 30, 2006 | 04:02 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by Archgator
...Any chance a '72 is different??
Nope. No chance, unless Bubba has been there.
Old May 30, 2006 | 05:10 PM
tigers123's Avatar
tigers123
http://www.vettespecialties.com/
They have them
To gauge bezel question
