L48 vs. L82 block casting number
Old Jun 4, 2006 | 07:22 PM
njcardave's Avatar
njcardave
Default L48 vs. L82 block casting number
I was told that if you have an engine block number that ends in 010 that it means that the engine block is a four bolt main. I have a 75 with a L48 engine two bolt main but my engine block number ends in 010. Does anyone know about this?
Old Jun 4, 2006 | 07:47 PM
Scott Marzahl's Avatar
Scott Marzahl
I think that is a urban legend. Your vin tells you if it is a L-48 or L-84 as does the block. CKC for a L-82 auto and I believe CKX for a L-48 auto. The L-82 was a 4 bolt main, the L-48 a 2 bolt main.
Old Jun 5, 2006 | 12:48 PM
mvftw's Avatar
mvftw
I believe the '010' means 10% nickel, there are also '020' blocks... I'm sure another member will verify...
Old Jun 5, 2006 | 01:12 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by njcardave
I was told that if you have an engine block number that ends in 010 that it means that the engine block is a four bolt main....Does anyone know about this?
010 = 4 bolt? Nope, not always. The 3970010 block has several Corvette uses; some four bolt (L-82), some two-bolt (L-48). Engine code stamped on the pad would be the best identifier.
Old Jun 5, 2006 | 04:06 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...exactly right. My '74 L-48 195hp motor is a "010" block and is two bolt. The "010" '73 Impala motor in my '68 convertible is a two bolt. The original "010" out of my '75 L-82 coupe is a four bolt.
Old Jun 5, 2006 | 04:47 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
right, the 010 was used on just about any GM car with a 350...........
To L48 vs. L82 block casting number
