Ya know, its never easy
but...
I did mine a lil different.
I went a little longer...but I also went wider and taller. I also avoided the parts stores and used the "belt centers" type of stores.
We have two in town, one is called (appropriatly): "The Belt Center" the other is "The Belt Store".
Same length but wider and taller actually makes a belt seem too short because of the V-groove size in the pulleys (not a drastic change) vs. actual length needed.
The belt may be sitting up a 1/16th (or less) of an inch slightly higher in the pulleys...but does allow for more surface contact than the stock size belt and no squealing at all.
I have always known factory replacement numbers for belts and hoses is ALWAYS a crap shoot.
A factory numbered replacement belt may be the same lenght but, too skinny...lenght-wise fits perfect...but sits very low in the pulley...equates to squealing and premature wear, or un-authorized breaking (because its new it shouldnt break).
Belt centers (usually all they do is sell belts and is knowledgable) can match length, add or subtract width and HEIGHT,, and recommend a better rubber compound.
Also; OLD PULLEYS can cause problems by not allowing full surface contact with the rubber in the V-groove....this is where a slightly wider and taller V-groove belt is the only option....but...you have to pay attention that the taller belt is NOT "bottoming out" in the groove allowing less surface contact...which is where "wider" comes into play.
And sometimes all it needs is just a wider belt to cure the problem, no height adjustment.
Add to the fact that; Bubba may have made some repairs...and one pulley groove is different size vs. the other...
example: harmonic pulley vs. A/C pulley....then add if somebody replaced a part with a re-man, and the re-man shop threw a pulley on that was sized incorrectly(re-man alternators are famous for this)....so many angles to the final solution.
But...
It all comes into simple terms....like building something.
ie...width vs. heigth. vs. length when it comes to belts, then add rubber compositions.
With those all figured in, you can cure any belt problem for the price of a belt only.
This even works with slightly mis-aligned pulleys.
I know it seems complicated...but it really isnt if you avoid part stores and their "replacement belt" part numbers.
GL
Jim
I did find a part number which is 1/2 inch shorter and I think that will do the trick. I'd rather do that than take a grinder to the adjustment slot and possibly weaken it.
