Here I go again....
Jun 5, 2006 | 09:55 AM
Cruise-In IV Veteran
Here I go again....
Why do I feel like listening to white snake now..
anyways..
I guess 4th times a charm
Jun 5, 2006 | 10:01 AM
might wanna try a professional....at this point might be cheaper
Jun 5, 2006 | 10:04 AM
Quote:
I...
AM a professional
Jun 5, 2006 | 10:05 AM
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Quote:
Originally Posted by Corz
I...
AM a professional
so as a profesional if you were a customer would you be happy with your work????
Jun 5, 2006 | 10:09 AM
Quote:
i wouldnt let it leave if it was a customers.
course, if it was a customers, they would have bought the best clearcoat out there, not this abomination that I tried out
note for future reference, avoid dupont nason clear coats
Jun 5, 2006 | 10:11 AM
so it was a problem with the clear coat product? what happened?
Jun 5, 2006 | 10:13 AM
Quote:
clearcoat fogged up...
tried to wetsand it and reclear it.. the entire hood turned dull
apparently with this clearcoat, you cant put it on thick like you can with the Chroma Clear or PPG line.. the thicker the coat, the worse it fogs
Jun 5, 2006 | 10:14 AM
just because you know which way to point the gun doesnt mean your professional...
..made a living this year from paint?
really though Corz just giving you a hard time,...
Jun 5, 2006 | 10:15 AM
welll this begs the question, what dod you use on the rest of the car, and why did you change or why did you fix something that wasnt broken
Jun 5, 2006 | 10:18 AM
what was your flashtime?
45 minutes between base and clear
I used Chroma Clear on the rest of the car, I changed because this stuff was lyin around from a past project I did, had good results with it before but now it just decided to f with me.
as for fixing somethin that wasnt broke, It actually got pretty badly scratched from storage over the past year, so I tried to blend and thats when my downfall began
Jun 5, 2006 | 10:20 AM
http://www.digitalcorvettes.com/corv...efinished1.jpg
see if you can tell where I painted
