Power door lock problem
Old Jun 6, 2006 | 11:32 PM
tbcbi's Avatar
tbcbi
Default Power door lock problem
Have an '82 collector. When I lock driver side door, the passenger side door opens and vise-versa???????????
Old Jun 7, 2006 | 08:27 AM
bluesilver82's Avatar
bluesilver82
well, If someone has monkied with it you have a wire or two swapped, If they have not been messed with you have a short. The 82 shop manual will have a wiring diagram. Get a copy of the diagram and a voltage/continuity tester and check it out. I have the shop manual. If you give me a fax number and I can fax you copy from my shop manual. Im at work now but I can bring the manual to work tomorrow and send it to you then.
