I'm prepping my Vette for paint following Lars' paper, and have a few questions. First, I used a Primer/Sealer before doing the body work. Its been a while since that was applied. Is it a good idea to spray another coat over the bodywork, before the K36 primer/Surfacer? My thoughts are that any contaminants that may not clean off completely, although I'll try, will have a harder time bleeding through the sealer. Second, is there a glazing putty I can use to fill small scratches in the filler?
You mentioned using primer/sealer first then you did the body work, I assume you used an epoxy primer. Depending on what brand of epoxy you used, there are different recoat requirements. Transtar epoxy need only be sanded with 400 and recoated with your K36, no time limits. If you used PPG DPLF, you need to sand with 400 and recoat with DPLF again because you've waited beyond the recoat time. Make sure you recoat the DPLF with the K36 within one week, or you'll need to recoat again with DPLF which can get very costly.
Use the K36 to block sand the car to smooth the panels and remove sand scratches and pits. When you are ready to top coat with color, use DPLF again but with reducer this time, it makes a good sealer for the top coats.
Make sure you have all of the product sheets for reference.
Actually it should be done to prevent moisture corruption. Fiberglass panels are bad to soak up moisture. the epoxy primer creates a shield and barrier.
Yep. If you use epoxy primer over the bare body first. Epoxy primer adheres better to fiberglass and metal than urethane and acrylic primers do. Body fillers adhere better to epoxy primer than to fiberglass or metal. Paint the epoxy, apply filler where needed and shape it like always, then apply your sanding primer such as K36.
Works especially nice on steel cars where you don't want bare metal to rust while your doing minor body work.
well thats a given.. assuming the car gets stored outside.. but I've always done a urethane after my panel work on glass cars. on a mteal car, I use self etching primer then urethane.
I've actually never used a "filler" for the polyester fiberglass; just the usual case of resin and matting, then sand that to shape, prime, block, prime etc till it's perfect.
my way probably takes more time but.. its worth it in the end
I've worked on a lot of fiberglass. Using sealer first is a waste of money. If you are using fiberglass reinforced, plastic, or vette panel body filler, you do not want to put this over primer. It must be on bare fiberglass that has been roughed up. Polyester glazing putty can be put over primer, but it must be roughed up with 80 first. Do your major body work first then apply a urethane filler primer. If you have any small places that need filled after sanding the body, use the putty. Prime again and sand. I don't see where an epoxy would be a better moisture barrier than urethane. Catalyzed urethane is waterproof. An epoxy or urethane sealer is made to be sprayed right before the paint. Sealer is applied, wait about 15 - 30 minutes, then apply paint. No sanding is necessary. Some epoxies are not meant to be sanded and they are usually harder to sand.
