clutch push rod
Old Jun 12, 2006 | 10:53 AM
markbett's Avatar
markbett
Default clutch push rod
Drivn' along going from first to second and SNAP! the clutch goes to the floor. I pull off the road ad open the hood and I see the clutch push rod is in 2 pieces. Question: How hard is it to replace and PLEASE tell me it can be done without removing the dash.
Old Jun 12, 2006 | 11:11 AM
Gordonm's Avatar
Gordonm
It is not a problem. No dash removal needed. It is tight working up there but it is accessable. You should be able to get to the pedal and undo the clip and slide what is left out of the car.
Old Jun 12, 2006 | 11:17 AM
markbett's Avatar
markbett
Thanks, That piece looks like a pretty weak design, the thing snapped right at one of the adjusting nuts.
Already ordered the new one with any luck, I'll able to make the Lansdale car show this Saturday.
Old Jun 12, 2006 | 12:15 PM
Edzred72's Avatar
Edzred72
If your a big guy, removing the seat & steering wheel will help tremendously. I'm not a big guy...but remove them anyway.
eddie
Old Jun 13, 2006 | 04:40 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
it is highly advisable (ask me why) to inspect the stud coming off the clutch pedal when you replace the rod. brother, fixing that does require dash removal.
To clutch push rod
