Verifying options
i know on C4's we are able to purchase our build sheets, but on a c3 what do you do? I just dropped the tank in my 71 and there is no build sheet or any indication it was ever attached to the tank. How can you verify that your car is a big block car if the #'s don't match?
BB cars have bolts & caps on the U-joints instead of straps.
They have a rear sway bar stock.
They should also have a 4 core rad.
I have also been told you can tell whether it was a triple carb or single by the return fuel line!
Triples---no return line.
Single ---return line.
Could anyone confirm or disclaim this ??
Originally Posted by js292
....How can you verify that your car is a big block car if the #'s don't match?
Good point on the absence of the tank sticker. Lots of folks go looking for one and don't find it.
Good luck with the hunt.
4 core ; check
I'll have to look at the u-joints tonight
