Door Mains.
Old Jun 14, 2006 | 09:31 PM
JustForFun's Avatar
JustForFun
Default Door Mains.
What is the trick to install the door main weatherstrip. glue a little piece and hold it for 2 hours until it sets up? Cant seem to find the trick that works.
Old Jun 14, 2006 | 09:55 PM
1971Coupe's Avatar
1971Coupe
what year is your vette?
on my '71, screw both ends in place, apply adhesive, wait 10 minutes until sticky,
set everything in place, after a while shut the doors, enjoy a beer and a smoke
Old Jun 15, 2006 | 08:14 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I used masking tape on mine until the cement set.
Old Jun 15, 2006 | 09:25 AM
NHvette's Avatar
NHvette
You can use the weatherstrip adhesive like contact cement.
Apply adhesive, push together, pull apart, let dry a few minutes, and push back together - stuck. If adhesive is still too wet, pull apart and
let dry a few more minutes.
To Door Mains.
