1969 engine date code window
Old Jun 15, 2006 | 09:23 AM
c369's Avatar
c369
Default 1969 engine date code window
I do not have my original 350/300hp block for my 69. What is an appropriate window prior to the assembly date of the car for the date code of the engine? I hear 3-6 weeks and it could be a two bolt main.
My assembly date is in March of 69. Does someone have an engine or can someone lead me to the right person. I am in central California.
Old Jun 15, 2006 | 09:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by c369
....I hear 3-6 weeks...
You hear correctly; could even be as little as two weeks. As an example, the engine in my '68 was assembled on April 9th; the Time/Build date on the car is April 20, or eleven days later.
Good luck with the hunt.
Old Jun 15, 2006 | 11:57 AM
RobRace10's Avatar
RobRace10
Is the assembly date the date stamped in on the engine pad and the engine build date the cast in numbers? My 69 seems to have a couple months between them but GM had a strike about that time so I figured that was the reason.
Old Jun 15, 2006 | 01:22 PM
Easy Mike's Avatar
Easy Mike
The strike in '69 did not begin until April, so your March car should have missed it.
The engine has an assembly date stamped on the pad. That's the day it was assembled at the engine plant (Flint, Michigan for all Corvette smallblocks). The format will be VAAAAXX. The As stand for the calendar date (i.e. 0301 for March 1st). The Xs will be alphabetical characters for the engine suffix which identifies the application the engine was built for(i.e., standard trans or auto, California emissions, etc.).
The Time/Build date is on the trim tag and indicates the calendar date the Corvette passed the station on the line where the trim tag was attached. This station was before body drop so the car would not necessarily have been completed on that date. Usually needed another day or day and half to be completed.
What's the time/build date for your '69 (upper right corner of the trim tag)? Subtract 2-6 weeks from the time/build date and you will be in the ballpark for the engine assembly date.
Old Jun 15, 2006 | 06:10 PM
Mike Ward's Avatar
Mike Ward
NCRS will accept up to 6 months prior to the car completion date, if that's important to you.
Old Jun 16, 2006 | 09:10 AM
c369's Avatar
c369
I believe I found a block. Thanks for the help. This forum is great!!!
Old Jun 16, 2006 | 09:52 AM
Easy Mike's Avatar
Easy Mike
To 1969 engine date code window
