I have a picture posting question. Do I have a option on if a attached picture is a full picture or a thumbnail. I'm a supporting member and would like to post a regular size pistures and not thumnnails, AL.
Not sure when your a supporting member, but for the rest of us, here's the drill. FWIW.
What you need to do to post pics is to first upload your pic(s) to a location on the internet. Some people use cardomain.com, photobucket.com, photohost.org or if your ISP provides you with some webspace, that will work too. Then in your post, click on the "Insert Image" button (directly below the right side of the font "size" box) and then place the whole address to the pics within the box that appears. To finish click the OK button and what ends up within your post should look something like this.
Note that the image tags (img) are misspelled (image) so they will show up here and not actually try and display a picture.
I'm a supporting member and can post full size pictures. I don't think supporting or not has anything to do with picture size. I resize mine after downloading from the camera, before going to Photobucket. I think they can be resized on PB as well. You are able to post pictures, just not the size you want, is that correct?
