decided to put back my speedo minus the Tach until i can get it fixed.
"while i was at it" since i had the steering wheel off i decided to clean and dye it also cleaned up the horn contact buttons.
horn blows first time every time now.
I forgot to add my while I was at it. Broke a bolt off in the intake (thermostat housing) $1000 later I have a new intake, carb, air cleaner and fuel lines and other acceories
I think only pansy's wear blue gloves. And my proctologist.
WOW you guessed my profession, you are an amazingly astute
person. i bet you were so bright as a kid your dad called you SON.
on top of that just a tip for you.
oils/sweat from your hands will not allow dye or paint to adhere to leather/vinyl/metal/plastic or any other surface.
so whenever im painting or dying something that i want the finish to last on. YES, i will wear nitrile gloves and look like a pansy rather then take a chance and have to do it all over again.
Might be little late to tell you, but i really think he was joking. Why do people let such small things overwhelm them to the point they loose their sense of humor? Im also sure your reply wont make things any better. Always has to be one in every group.
makes you wonder why some people even post. Too bad we cant be one nice big family. If you dont like whats said, just move on. Guess i should have done the same.
The niceness of how your steering wheel turned out, is now over shadowed by your response.
over shadowed by my response? i don't think my response was bad
and i found it to be as humorous as his.
"so bright your dad called you son" "bright/sun" get it?
whats wrong with that?
and then to let everyone know exactly why i wear the gloves i felt was a pointer not a personal dig.
i know a lot of people that wouldn't think anything of trying to paint/dye a part after handling it with bare hands then 2 months from now wonder why the item started to flake and then bit*h because they have to do it all over again.
personally i don't see what was wrong with my response and i stick by it
Ok back to the subject at hand, it came out damn nice! I just had a case of the same problem. I went ot replace my headlight switch and wound up dying the entire dashboard.
