New C5 Wheels
Old Jun 17, 2006 | 08:57 PM
TheMongoose's Avatar
TheMongoose
Default New C5 Wheels
Here's the fronts. I need bigger adapters for the rear so they'll have to wait till later in the week. I got 2-1/2" and I need 2-3/4 for mine to sit right. (This pic is with the 1st of 3 buffing steps done, then I have to wax it)
Old Jun 17, 2006 | 09:37 PM
stingraymaniac's Avatar
stingraymaniac
looking good
Old Jun 17, 2006 | 09:41 PM
mlub's Avatar
mlub
i'm diggin the polka dot interior
Old Jun 17, 2006 | 09:43 PM
onaqwst's Avatar
onaqwst
prolly brings out his eye color
b
Old Jun 17, 2006 | 11:27 PM
gator79's Avatar
gator79
[QUOTE=TheMongoose]Here's the fronts. I need bigger adapters for the rear so they'll have to wait till later in the week. I got 2-1/2" and I need 2-3/4 for mine to sit right. (This pic is with the 1st of 3 buffing steps done, then I have to wax it)
why do you have to buff it 3 times? did you color sand it? looking good
Old Jun 18, 2006 | 12:35 AM
Bee Jay's Avatar
Bee Jay
Lookin' good. Where did you get the L88 hood. Every L88 hood I see in catologues only fit 68-72. I have a 79, and I want an L88 hood bad.
Old Jun 18, 2006 | 12:37 AM
Bee Jay's Avatar
Bee Jay
I just switched to 2 1/2" adapters on the rear from 2 3/4". The 2 1/2" work perfectly for me.
Old Jun 18, 2006 | 04:45 AM
Demonic Possession's Avatar
Demonic Possession
Did you let the paint cure enought before you wax it?
Old Jun 18, 2006 | 07:58 AM
TheMongoose
[QUOTE=gator79][QUOTE=why do you have to buff it 3 times? did you color sand it? looking good [/QUOTE]
The 3-stage system from Presta is a cutting creme, a polish, and a swirl remover. 4th step is to wax it.
I color sanded at 1500 and then 2000 grit. Really seemed wrong to sand down a perfectly good finish but once you get to the swirl remover the depth in th epaint really pops!
Old Jun 18, 2006 | 08:01 AM
TheMongoose
BeeJay, I had seen your post earlier and thought I would be set. Every car is different though I guess. My wheels are still inside the wheel well right now and I'm hitting on the spring and also on the e-brake cable. I ground the cable mount down and it clears that although the cable itself has to be bent out of the way t clear. Looks like going up 1/4" in size will clear everything for me.
It's kinda like my front end...the drivers side wheel barely clears the front of the wheel well and passenger side baely clears the back f the wheel well, go figure. When I measured it turns out the fender on the PS sits 3/4" forward of the DS.
Old Jun 18, 2006 | 08:05 AM
TheMongoose
I went with a single stage paint and not base-clear. It had sat for a month though while I was sanding out each stage and then color sanding the clear just because I worked on it in my spare time. I was told not to do anything for 30 days on the old paint systems( my buddies dad painted my 77 Olds Cutlass back in 1984). With this they had me sanding and buffing right away. No waiting. They do every car over at the DIY shop this way so it seems to work ok. Anybody out there have a knowledgeable reason why? Mine is just a guess based on what I see.
Old Jun 18, 2006 | 08:07 AM
TheMongoose
Bought it off the forum here. Oddly enough after looking fo 6-months I posted a 'wtb' ad and got a reply! They sell the long L-88 hood at Ecklers for sure. I looked at them and had figured I was going to have to drop the bucks for one.
Old Jun 18, 2006 | 10:49 AM
Bee Jay's Avatar
Bee Jay
Thanks, I'll try a WTB add. I thought the Ecklers long L88 wouldn't work on post 73s. I can't tell, but what C5 wheels did you use? Maybe they have different offsets. My big problem was the rear sway bar, which I modified.
Old Jun 18, 2006 | 12:15 PM
TheMongoose
I can't say it's guaranteed but i think it fits up to '80 or 81? And maybe that's with some modification based on the experience I had with mine. I looked at the hood latches and they ligned up correctly for my 76. The only issue was with the corner tips up near the windshield. They did not flare up to match the fenders; they went straight essentially. I made a cardboard pattern and fabricated a corner to match my fenders. Took me 1 night to fab it up, glass it in. Then the next night i put filler on it and shaped it.I probably have 6 hours into them total. Now it looks like it belongs on the car. Most people probably wouldn't have noticed the mismatch right off. It was about 1/2" low and about 1-1/2" long at the very edge here the corner didn't meet the fender.
I got the Z)6 Motorsport wheels in black. Your probably right the offset is probably 5mm different on those than yours, or some goofy thing like that. Hopefully I can get new adapters quickly this week and exchange 2 of the ones I have. Can'twit to get them on all-around!
Old Jun 19, 2006 | 12:41 AM
Bee Jay's Avatar
Bee Jay
Going from 2.75" to 2.5" adapters required new adapters. Going from 2.5" to 2.75", you could use 1/4" spacers between the adapter and hub. You will have more than adequate number of threads remaining for the adapter nuts.
Old Jun 19, 2006 | 01:14 AM
Corz's Avatar
Corz
Cruise-In IV Veteran
silicone... thats why. Silicone will trap the paint while it's still breathing. once the paint is fully cured (base coat or single stage) then silicone wax is fine. Your buddy's dad probably used buffing compound which contains NO silicone at all
Old Jun 20, 2006 | 11:16 PM
TheMongoose
I was thinking about that tonight. Any chance of getting more runout because f combining the two sets of adapters and spacers? as long as there wasn't any additional chance of the nts loosening up I think it would be fine. Any thoughts on this anyone?
To New C5 Wheels
