How do I remove the speedo cable.
Old Jun 20, 2006 | 05:40 PM
munday's Avatar
munday
Default How do I remove the speedo cable.
There looks to be a grommet through the firewall. I don't want to break the grommet. Is there a special way to loosen that grommet.
Old Jun 20, 2006 | 06:03 PM
Z-man's Avatar
Z-man
If it's original, it's probably baked and hardened to the consistency of steel. In that case, you'll probably have to remove it in pieces with a pliers.
Those grommets are cheap. It might be better just to replace it...
Old Jun 20, 2006 | 06:14 PM
munday's Avatar
munday
okay i'll be back i like breaking stuff. and it's as hard as abs.
Old Jun 21, 2006 | 12:47 PM
C3 4ME's Avatar
C3 4ME
yup, mine took a beating when I replaced my speedo cable.
Old Jun 21, 2006 | 08:57 PM
munday's Avatar
munday
okay damnit, now where does it go. Do I have to remove the dash to get to it?
Old Jun 22, 2006 | 07:49 PM
Z-man's Avatar
Z-man
To get to what? Aren't you looking at the grommet from the engine compartment?
Old Jun 22, 2006 | 08:37 PM
Duke94's Avatar
Duke94
The speedo grommet on my 78' had a steel washer with spring type fingers molded into the rubber. Use a screw driver and pry it out of the hole in the firewall.
Old Jun 22, 2006 | 09:53 PM
munday's Avatar
munday
Yeah I see where it connects on the pedal at the top just don't see how to pop off without removing the pedal assembly.
Old Jun 22, 2006 | 11:02 PM
munday's Avatar
munday
fck it I just took of the dash which looked like sht anyway. Got it.
To How do I remove the speedo cable.
