Converrtible Deck Lid Adjustment
Old Jun 21, 2006 | 03:48 PM
GOLDEN65CPE's Avatar
GOLDEN65CPE
Default Converrtible Deck Lid Adjustment
The gaps on my Decklid are narrow on drivers side and wide on passenger side. Also not parallel. Adjusting at the hinges should correct both problems. What can I expect as far as the convert top pin attachments at the lid. Also both the Conv. top and hardtop alignment at the windshield header.
Old Jun 21, 2006 | 04:21 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Aligning the decklid should not affect rear bow attachment. Not unless it's way far out of whack.
Old Jun 21, 2006 | 04:44 PM
crazywelder's Avatar
crazywelder
Al, You can adjust the gaps with the hinges. You will probably need to adjust the rear pins as well to avoid stress on the top frame. The deck adjustment will have no effect on the front header pin location. There are several adjustment points for the soft top, if your goal is to even up the gaps, okay, but if the top isn't fitting properly now, that's a different story and adjustment.
Old Jun 21, 2006 | 10:28 PM
Sayfoo's Avatar
Sayfoo
Just did my 69, and I had to enlarge the slots on the hinges to get it to line up right.
To Converrtible Deck Lid Adjustment
