Lokar throttle cable question.
Old Jun 22, 2006 | 11:04 PM
munday's Avatar
munday
Default Lokar throttle cable question.
The fitting that is on the end of the cable of course is not for a vette. However it looks like the cylinder has enough weight to hold it down on the throttle bar. Will I be fine with a rubber grommet to prevent wear?
Old Jun 23, 2006 | 06:35 PM
A C's Avatar
A C
Cruise-In II Veteran
Which end are you talking about? The gas pedal end?
Old Jun 23, 2006 | 08:17 PM
C3 Stroker's Avatar
C3 Stroker
Just remove the cylinder and place the "ball" end with a grommet through the throttle bar the same as the stock one was.....it will work OK.
Old Jun 24, 2006 | 01:20 AM
Stumpdeisel's Avatar
Stumpdeisel
I was trying to figure out the same thing, thanks!
To Lokar throttle cable question.
