Wheel Questions
Old Jun 23, 2006 | 08:26 PM
Meh's Avatar
Meh
Default Wheel Questions
Just installed a set of Torque Thrust IIs (17x8) with 245/45/17 Goodyears. Anybody know the recommended tire pressure and lugnut torque specs for this setup?
Old Jun 23, 2006 | 09:20 PM
71rdster's Avatar
71rdster
Tire sidewalls should indicate recommended tire pressure. Torque specs for lug nuts should be same as for factory wheels.
Old Jun 23, 2006 | 09:30 PM
Meh's Avatar
Meh
Sidewalls only indicate the maximum pressure, and the factory specs are for steel wheels. Wanted to make sure it's correct for aluminum wheels.
Old Jun 23, 2006 | 11:49 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
I have a set of 15" TT2's and torque the lugs at 85 ft/lbs and have had NO problems.....
Also, I went ahead and purchased a complete set of McGard solid chrome lug nuts....so far NO RUST!
Old Jun 24, 2006 | 02:30 AM
Meh's Avatar
Meh
Cool, thanks. One question down, one to go...
Old Jun 24, 2006 | 03:50 PM
Meh's Avatar
Meh
Bump.
Tire pressure for 17s, anybody? That rubber gets expensive if you wear it out prematurely.
Thanky thanky...
Old Jun 24, 2006 | 05:55 PM
mkflanagan's Avatar
mkflanagan
NO!!Do not use the pressure on the sidewall that is not the recommended pressure,it is MAXIMUM pressure for that tire.That is a common mistake I see alot of people make.I would run about 32 pounds.
Old Jun 24, 2006 | 06:02 PM
Meh's Avatar
Meh
Not to mention it would ride like the Flintstones' car.
Old Jun 24, 2006 | 06:55 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
30lbs cold
To Wheel Questions
